Lexus wheels with low offset
Old Oct 9, 2010 | 10:16 AM
mjz's Avatar
mjz
Default Lexus wheels with low offset
I can't find the proper forum to ask this, but I'm looking for a set of Lexus 18"x8 wheels with low offset.
Generally, Toyota and Lexus wheels have a very weak offset, but I don't feel like using spacers and I want to stay OEM (and not use hubcentric rings) (but may not be able to).
In any case, is the F-Sport 18" the best Lexus gets (+40mm)?
Old Oct 10, 2010 | 06:11 AM
mjz's Avatar
mjz
Any thoughts? Should I just get the F-Sports that are on sale now?
Old Oct 10, 2010 | 08:55 AM
ScKcBc's Avatar
ScKcBc
Lexus doesn't make low offset wheels. I have a set of 2010 is350 convertible wheels for sale but they are 45mm and 50mm.
I don't understand why your opposed to using spacers on OEM wheels or using hubcentric rings with aftermarket wheels? It's not a big deal at all. If you get spacers, get the project Kics that have the studs built in
Old Oct 10, 2010 | 07:06 PM
m3nv's Avatar
m3nv
All OEM Lexus wheels will be high offset. Even their coupes likes the SC430 use really conservative offsets.
Old Oct 11, 2010 | 09:37 AM
mjz's Avatar
mjz
I just hear horror stories on spacers and safety issues.
Old Oct 11, 2010 | 09:51 AM
mahcah's Avatar
mahcah
Yeah that's why I'm not running spacers. I don't want to risk it.
Old Oct 11, 2010 | 01:09 PM
ScKcBc's Avatar
ScKcBc
Bah, thats because people dont do things right. If you run a hubcentric spacer with countersunk lug nuts and replacement studs, then you'll be fine.
People use like, 10mm spacers and then retain the stock studs. Then when they put they're wheels on, they barely have any threads, stripping the stud and/or lug, giving it a week connection. Then they lose 2 wheels on the hwy and blame the spacer. Or they don't have the spacer bolted flush. Or the wheel isn't flush. Or they don't use a hubcentric ring to center the wheel on the spacer (if required). These are all the things people don't do and they have problems and then post horror stories.
If you get a solid spacer around 20mm-25mm with countersunk nuts and put them on properly (I'd use AT LEAST a mild loctite) then you'll be fine. OR, buy aftermarket wheels like millions of other people do and use hubcentric rings (which only center the wheel on the hub and do not bear any weight or real stress).
murfman89
Aug 22, 2017 08:49 PM
Boyracer40
Wheels, Tires & Brakes Forum
May 14, 2011 08:32 AM
YupImJOee
GS - 1st Gen (1993-1997)
Feb 25, 2009 03:39 AM
