Can I run with ECT Power mode continuosly?
Old Jan 19, 2013 | 09:22 AM
  #361
Silvex's Avatar
Silvex
I still don't get how this applies
to me/ what I have done?
Silvex
Old Jan 19, 2013 | 09:29 AM
  #362
Silvex's Avatar
Silvex
Ok, got it now!
"Yes. 10 char" = 10 characters
Right?
Silvex
Old Jan 21, 2013 | 01:00 AM
  #363
Silvex's Avatar
Silvex
Question What ECT power actually does
Originally Posted by Kurtz
What ECT power actually does-
Am I right in assuming that there a typo in the first sentence of this TIS extract:
" ... ... enables the ECM to estimate the road condition, driver's intention, the driver's intention, and the ...... "
i.e. repeats "driver's intention"
Silvex
Old Jan 21, 2013 | 01:12 AM
  #364
Silvex's Avatar
Silvex
Do we know why the driving mode switch "PWR/ECT/SNOW" is not 'sticky'.
That is for example, we can't leave it permanently in PWR-ECT.
(That's what I'd like to do!)
We have to select it every time we go out in the car.
Silvex
Old Jan 21, 2013 | 01:21 AM
  #365
freshtapco's Avatar
freshtapco
Silvex
Is it a UK model thing? Mine stays in PWR-ECT mode. When you select it, it clicks into place.
Old Jan 21, 2013 | 07:15 AM
  #366
jgr7's Avatar
jgr7
Silvex
Mine also stays in till I change it out.
Old Jan 21, 2013 | 09:39 AM
  #367
Silvex's Avatar
Silvex
It could well be a UK thing.
I never thought of that.
But you have now sown seeds of doubt in my mind.
Am I sure it goes off after I turn off the ignition?
I will go out to the car soon and check it (we've got a lot of snow here in the UK right now)
Just to try to make myself clear.
It's like the heated rear windscreen, for example.
If it is on when you turn the ignition off.
You have to switch the heated rear windscreen back on again.
Does that make sense?
Silvex
Old Jan 21, 2013 | 11:41 AM
  #368
nosurprise's Avatar
nosurprise
For the defogger, even US cars do the same, it turns off after 15 minutes.
Old Jan 21, 2013 | 12:04 PM
  #369
Silvex's Avatar
Silvex
Ok, agreed.
I don't want to labour the point.
But another example would be, Cruise Control.
As soon as you turn the ignition off, the Cruise Control goes off.
You have to activate it, if you want it, next time you switch the ignition on.
Silvex
Old Jan 21, 2013 | 04:07 PM
  #370
brociouz's Avatar
brociouz
On my US spec car you can select Power ECT and leave it there indefinitely. The switch physically "locks" into place when you select power mode. However, snow mode does not lock into place and needs to be selected each time you start up the car.
Old Jan 21, 2013 | 05:23 PM
  #371
LexStylez's Avatar
LexStylez
Same as my Canadian spec car.
Old Jan 21, 2013 | 05:57 PM
  #372
tacosmashr's Avatar
tacosmashr
Both my 4runner and IS350 will stay in PWR mode indefinitely. I've never taken my 4runner out of PWR (since I put 255/85 tires on it) since it actually helps a good bit even out the gas mileage with much larger tires than stock.
Old Jan 22, 2013 | 02:28 AM
  #373
Silvex's Avatar
Silvex
It works!
That's a relief.
I went out to the car just now to test it.
I don't know why I thought it switched itself off ... ....
Thanks to all for your advice.
Silvex
Old Jan 22, 2013 | 03:49 AM
  #374
Silvex's Avatar
Silvex
Does anyone know.
When the pattern switch is in the "Normal" position and the shift lever in the D position, what data is being sent by AI-Shift Control to the ECU?
Silvex
Old Jan 22, 2013 | 11:45 PM
  #375
Silvex's Avatar
Silvex
Where is Kurtz and the others when you need them? :-)
What I would really like to know is this.
Does the AI-Shift Control function still pass data to the ECU even when the pattern switch is in the "Normal" position and the shift lever in the D position?
Silvex
