Will those Wheels Fit an IS250 AWD - Part Uno
#497
Will I need to roll fenders with that size of tires? Will it scrape ? 😁 new here sorry for so many questions.
Thank you 😊
#498
Will 235/40/19 19x8.5 all around fit my 2011 Lexus IS250 AWD with no rubbing in the fenders? Any recommendation? I’m trying to ride smooth but also I’m not tryna rub tires. Lol
Thank you for any help
#499
Hcinthia08, what is the wheel offset and how low are you? If it's +35 to +40, and you're lowered about 2" all around, it should look a lot like my old setup.
My old 19" setup - SSR Werfen GT-03 with Fuzion ZRi tires. (I should never have sold these wheels...)
This was a staggered width setup, so ignore the rear as they were 10.5" wide. The front shows 19x8 +37 with 235/35/19 tires. The car was lowered just under 2" at the time, if I remember correctly. I had no rubbing issues that I can recall.
I think that you could probably go to a 40 series sidewall without issue, not 100% sure though.
#500
+35 offset , btw looks nice 👍🏼! But did you ride smooth with 235/35? I’m not tryna feel any rock haha
#501
Well, coming from the stock 17s, any lower profile tire will feel more rough. If comfort is your concern, I wouldn't bother changing the wheels at all.
For me, the ride did get stiffer. While I wouldn't say that I could feel rocks or anything like that, driving over seams in the concrete did feel more pronounced. Your tire brand/model choice will also have an effect on feeling and comfort. Usually cheaper tires (like the Fuzion ones I had) are harder, so they are not as comfortable as a tire with a slightly softer rubber compound.
In the end, I can't tell you how it will feel and whether or not you'll be okay with it, because each person has a different level of what they feel is too stiff or too soft. You might just have to bite the bullet and do it, then decide for yourself after driving on the new setup for a while.
#502
yes you’re right, thank you 😊
#503
F-Sport Forged Rims AWD
I have a 2008 IS250 AWD.
To avoid issues with staggered sets on AWD, will getting an equal set of the 19x9 REAR Rims work alright? What size tire do I get to avoid rubbing?
#504
Use this site: www.willtheyfit.com
Plug in your wheel and tire measurements to get your stock rolling diameter, and make sure your new setup is as close to stock as possible.
#505
IS 250 RWD 19’s squared Stock suspension
Would running 19x8.5" rims all around look odd w/o a lowering springs or coilovers? I just want to get the stock 17s off my AWD and would like to put 19s on -- assuming it doesn't look dumb. Thoughts? Any pics of an AWD w/ 19s that is not dropped? Thanks.
Looking at putting on aftermarket tires: 245/35-19 (tire height: 25.75")
Stock tire specs: 245/45-17 (tire height: 25.68")
#506
Anyone know if 19x9.5 and 19x10.5 with 0 offset all around will work? Is anyone running a similar set up?
Fenders are already rolled and I’m currently on a 19x8.5 all around with +30 offset front and +15 rear. Tire to fender in rear already with no space.
#507
Hmm "0" offset will push your wheels quite a bit past the fenders. If you want to go that route you might need to get camber arms.
itsAJayyee (08-29-19)
#508
Suspension parts help for aggressive fitment
Hello guys, I am currently having a very hard time finding Suspension parts to fit 19x11 wheels on my 08 IS250 AWD. I looked into Figs but seems like they don't want to deal with it so now im at a loss as the only other brand I see is Megan or SPC and I don't think those will be enough. Help!! 😫
#510
Not sure how much camber do you need to clear those. Your other option is machining the backpad of your wheels.
