Will those Wheels Fit an IS250 AWD - Part Uno
#377
I was talking about the famous "1%" difference in tire rotation. I believe it's the diameter and speed variance that you want under 1%, so I was curious how close to stock that set up is. Thanks again.
#378
Probably not if you're only lowering 20mm. I've lowered mine on coils probably 2.5"? This is my car on 18x9.5" +30, with 245/40/18 tires. Camber in the rear corrected to -0.5 degrees, I believe the same for the front. So your wheels will sit out just like mine do, but you'll have more wheel gap.
I do rub up front though, to the point where I had to bend back the metal on the bumper tab. I haven't gone as far as relocating the bumper tab like others have done though. Keep in mind, I'm running 245/40, so even at my height if you run 225s you shouldn't rub anything but the fender liner.
#386
Probably not if you're only lowering 20mm. I've lowered mine on coils probably 2.5"? This is my car on 18x9.5" +30, with 245/40/18 tires. Camber in the rear corrected to -0.5 degrees, I believe the same for the front. So your wheels will sit out just like mine do, but you'll have more wheel gap. I do rub up front though, to the point where I had to bend back the metal on the bumper tab. I haven't gone as far as relocating the bumper tab like others have done though. Keep in mind, I'm running 245/40, so even at my height if you run 225s you shouldn't rub anything but the fender liner.
#388
Looking to purchase a set of wheels with the following specs for my IS AWD:
Wheels (front and rear):
Diameter = 19"
Width = 8.5"
Offset: 35 mm
Tires:
235/35/19
Will these work without any fender modifications? Also, will they sit flush?
Thanks in advance!
Diameter = 19"
Width = 8.5"
Offset: 35 mm
Tires:
235/35/19
Thanks in advance!
#390
pretty sure it will fit but want to be 100% sure: 18x8 with 45mm offset will fit 225/40/18 tires all around? i have awd and currently have stock wheels 17x8 45mm offset. will wheels with 40mm offset fit the 225/40/18? sorry, new to wheels. tia.
