My LC818 are.....
It's a lot less than before for obvious reasons. haha
Same symptoms and everything. Only when hitting a bump at a moderate rate of speed.
I just wanted to clarify: "Shave some of the bold head" = you're speaking of the bold that holds the tab together?
Thanks!
how does that not sound safe?....relocate the screw further in shave off the bolt and slam that metal plate up with a hammer. did the job nicely for me. its been done multiple times. also you can use zip ties instead of a screw.
As another member so eloquently put it
"wow, I'm suprised at the garbage advice in this thread, aka "buy new wheels"... wow
Hartawan, I'm actually suprised your only NOW rubbing through your fender liner, especially running 20's. I rubbed though that ish the first month I had my IS and I'm rolling on 19's.
19x9 +28
19x10+28
to be exact.... and guess what no, rubbing.
here's the "secret".
FIRST: - either have a bodyshop/someone that know how to cut off/shave down that metal piece - do that. Then, bend UP that tab that connects the bumper to the fender. Bend that ish straight UP till its almost 90 degress and get it out the way.
SECOND: - take a heat gun and go absolutley nutz. I spent like 3 hours just heat gunning my front fender wells. Its actually quite a bit fun
Here's exactly what you gotta do. Look for any signs or signals of possible 'rub areas'. Get it crazy hot w/ the heat gun, then once its very hot/almost ready to melt, push it back away from where the tire would rub with something like a big rock (fist size or bigger). Then while your pushing it back, cool it down ASAP with cold water (ice cold spray bottle water). That way it will instantly harden and cool down in place where you pushed it back.
CONCLUSION: cut that metal piece off. bend up that tab. and have loads of fun going nutz with a heat gun, big rock and ice cold spray bottle.
DONE.
All other advice in this thread - disreagrd!"
Courtesy of mdgrwl, hope you dont mind me quoting u
https://www.clublexus.com/forums/is-...-pictures.html
19x9 +28
19x10+28
DONE.
BTW, how low are you? My tires are slightly tucking all around.
Thanks again!
well im on 20s and i slightly tuck. maybe liek 1.5-2" all around
here are some pics https://www.clublexus.com/forums/is-...me-advice.html
