Cutting rear spindle
Old Jul 8, 2010 | 01:22 PM
mikez's Avatar
mikez
Sounds like cutting your ***** off to fit into a tighter pair of pants
Old Jul 8, 2010 | 01:26 PM
JDKane527's Avatar
JDKane527
CL Folding 25,000
Old Jul 8, 2010 | 02:15 PM
kayotik's Avatar
kayotik
Lyle,
I have the flat silver caps and they fit fine without spacers. I don't know why yours doesn't?
Old Jul 8, 2010 | 02:50 PM
LyleBeach's Avatar
LyleBeach
Originally Posted by kayotik
Lyle,
Really? Interesting... I guess I'll see if it works for me. I haven't actually tried to see if it fit, I was just going off what Zoeb and the Wheel/tire shop told me.
What is your 2IS? Mine is a 10' 350
Old Jul 8, 2010 | 02:51 PM
kayotik's Avatar
kayotik
I put the caps on before putting the wheels on the car. It's a VERY close fit. The spindle pretty much pushes onto the cap, but i don't feel that it's going to pop out.
I have a 2008 IS250 RWD
Old Jul 8, 2010 | 02:55 PM
LyleBeach's Avatar
LyleBeach
Geez, well if it's that close then I may just try shaving a little bit of the inside of the cap with a Dremel or something. Could probably shave 1-2mm easy!
But maybe there is a difference between the 250 and 350 axle?
Thanks for the heads up! I'll check into this when I get home from work!
Old Jul 8, 2010 | 03:01 PM
kayotik's Avatar
kayotik
Yeah, I thought about doing that too (shaving the little plastic pieces on the back). But it fits fine and hasn't popped out or anything. It's pretty secure so I am not worried.
I'll show you the red caps soon
Old Jul 9, 2010 | 11:10 AM
LyleBeach's Avatar
LyleBeach
Upon further review, I took the wheel off and saw that there really isn't enough threads on the spindle sticking out, so I will not be cutting them.
However, thanks to the tip from Kayotic, I was able to remove the spacer and get the caps to fit.
I just had to Dremel some of the inside of the cap down, and they fit on there perfect!
Thanks for your guy's opinions and concerns for safety!
Old Jul 9, 2010 | 11:48 AM
kayotik's Avatar
kayotik
Good to hear! Got any pics?
Old Nov 24, 2010 | 03:18 AM
bigbum's Avatar
bigbum
I had to shave a the plastic behind the cap and they fit about 90%... went for a couple of hours drive, they ain't going anywhere.
Old Nov 24, 2010 | 04:10 AM
IXI187IXI's Avatar
IXI187IXI
you would think before doing something drastic like shaving the axle, you would know for sure that the caps dont fit.
Old Nov 24, 2010 | 09:10 AM
iialcii's Avatar
iialcii
new caps or spacers.
saftey always first.
Old Nov 24, 2010 | 09:19 AM
LyleBeach's Avatar
LyleBeach
Ya you're right! I guess I should just ignore what the manufaturer and distributer say.
I know Lexus tells me to use motor oil, but I think I'll just try out peanut oil, just to see for myself if it works!
ModInJapan
CL Vendor Products for RC-F
Jun 6, 2017 04:11 PM
niteLEX
Dec 9, 2010 03:39 AM
Kaydee
Wheels, Tires & Brakes Forum
Aug 30, 2007 03:45 PM
CAIFAN_64
Apr 28, 2007 11:50 AM
