"Range approx" number
Old Jul 20, 2010 | 12:55 AM
  #31
Fizzboy7's Avatar
Fizzboy7
My mileage just improved by two these past two weeks. Once the weather got hot, it helped.
Old Jul 20, 2010 | 10:15 AM
  #32
shaolin's Avatar
shaolin
check your tire pressure. Usually when it's low you get about 30 miles less.
I have 06 350 and i've got as high as 440 a tank before i hit the zero mark.. of course not every time.
I use to hit 390 to 410 before i fill up but now i get about 380. The car is old so ... understandable.
maybe time for new spark plugs...
Old Jul 20, 2010 | 11:03 AM
  #33
E6BAV8R's Avatar
E6BAV8R
Originally Posted by yahn0etran
How do you get that ?! Mine is around 260-280, I always have my AC on low do you think thats partially why? Because I spend more than 80 dollars a month on gas !
Not sure. I accelerate like a granny, so that is probably why. My AC is always on (I don't even know the last time I turned it off, actually). I drive a lot in the city too, and I spend probably about ~$80/month too with 93 Octane. My tank average ranges from about 29-30 MPG. I just filled up last week and I drive about 50 miles a day. Next time I fill up I'll grab a picture.
FWIW, I drive an '06 250 with 68K miles.
Old Jul 20, 2010 | 02:12 PM
  #34
MBTC's Avatar
MBTC
Just filled up last night with this thread in mind and it was at 380.
Old Jul 20, 2010 | 03:50 PM
  #35
SC3coupe's Avatar
SC3coupe
Something strange, I was at 2 miles to empty,
then I went to get 1 gallon of gas it was very late at night.
It didn't change the number or move the needle.
Then the next morning I went to get 2.5G of gas it changed to 105 miles to empty right away.
It it possible I didn't get the 1 gallon of gas the night before because the gas station messed up or was actually closed? I was paying at the pump itself.
Old Jul 20, 2010 | 10:15 PM
  #36
2009is350's Avatar
2009is350
Originally Posted by Stun350
I drive a 2008 IS 350.
i have an 09 350 and when i fill up i get around mid 270's
Old Jul 24, 2010 | 01:11 PM
  #37
kl323's Avatar
kl323
I have a 2010 350. Currently has 3700 miles on it. Each fill up, I get 300-310 miles. Do I still need to break it in more before I start seeing higher MPGs or longer range?
My lifetime MPG is 20.
My tank average is 18-20 mpg for each fill up.
I like to keep my Current MPG on the display while I drive. I make every effort to drive as efficiently as possible. I do notice that when cruising on the highway at 60-70 mph, the meter would show 30-35mpg. During city driving, I can get 20-30mpg.
I'm not too satisfied with gas mileage that I'm getting! I'd say my driving is 50-50 highway-city. I drive like a granny (RARELY going over 3k on the tach).
What's worse: Taking a long time going from 0-50mph at a snail's pace or going up to 50 at a comfortable pace without taking too long (while not flooring it)?
Old Jul 25, 2010 | 11:11 AM
  #38
E6BAV8R's Avatar
E6BAV8R
Filled up last night with the thread in mind as well, here you go:
Old Jul 25, 2010 | 01:26 PM
  #39
Toymota's Avatar
Toymota
If I remember correctly, 460+. I'll check next time I fill up. I have run a few tanks past 0 covering an actual 450 miles. 250 FTW! My lifetime AVG has never been reset for 11,000 miles and sits on 31.0 MPG.
Believe it or not, I drive about 80% city. My technique for good mileage is 'Driving Without Brakes'. It mostly involves coasting up to red lights. Better yet, time them so you don't have to stop at all. Accelerating kills your mileage. Try your best to keep a steady speed.
This also helps because the gas cuts off when you coast. You will see the Current MPG go to 90 (actually infinity). I think the way the IS automatic gearbox is designed, you get engine braking in gears 4, 5 and 6, so when you coast, the wheels are turning the engine and no gas is needed above idle speed.
Old Jul 25, 2010 | 02:56 PM
  #40
MBTC's Avatar
MBTC
I've always wanted to do this but it's insanely challenging for me, because it requires maintaining a safe distance between myself and the car ahead, and every time I attempt that some moron lane changes in front of me causing me to drop back more. If I didn't stake my claim now and then, I'd end up never getting to my destination.
Old Jul 25, 2010 | 03:57 PM
  #41
Phresh2010's Avatar
Phresh2010
i get somewhere between the range 320-340 on my AWD, i drive a lot of local also. and ive heard that even after the range apprx hits 0 you still have about 20-40 miles? i believe this is true cuz when i am at 5-10 miles till empty only about 15 gallons of gas would fill up my tank and i guess 2 gallons are for emergency use
Old Jul 25, 2010 | 04:03 PM
  #42
TokerIS350's Avatar
TokerIS350
440 in a is350?
thats insane!
i never get past 310
Old Jul 25, 2010 | 05:11 PM
  #43
Stun350's Avatar
Stun350
400+ on a 350?! That's crazy! That's what I'd expect for a 250. hmmmmm Yeah I filled up yesterday and got around 290-295 when in the past I used to get between 310-315.
Old Jul 25, 2010 | 05:22 PM
  #44
IS250chino's Avatar
IS250chino
370 on 93 oct.
Old Jul 25, 2010 | 05:28 PM
  #45
Silec's Avatar
Silec
i get 350-420miles in my 09 250. it all depends on how aggressive your driving style is in my opinion.
