starting problems
Old Apr 22, 2010 | 07:13 PM
moped's Avatar
moped
Default starting problems
So I just bought a low mileage is 250 Awd drive a month ago, everything was fine until the last couple of days. I try to start the car yesterday and it won't start, just hear the starter clicking over. So I get it jump started and go to work
when I try to go home no start again, another jump start.
This morning I go to work and it starts but with some hestation, I go to work,
and try starting it 7 hrs later, no problem, two hours later no start again.
Is this a bad battery? or what could be draining the battery?
Old Apr 22, 2010 | 07:55 PM
caudlek's Avatar
caudlek
Originally Posted by moped
So I just bought a low mileage is 250 Awd ..... problem, two hours later no start again.
I am driving a 2006 IS350 here in Ontario .... colder winters than you .... no battery issue yet. After 4 years in a cold climate it is not unusual for a battery to show its age .... if it has been run flat 2 or more times then you are on borrowed time at 4+ years. These vehicles don't have a history of starter or alternator problems.
Put a volt meter on you're battery .... you should see 12v at rest, and 13-14v when running with a good alternator. The battery would have to be tested under load to see if its OK or not .... even a crap battery will read 12v if its not under load.
You will still likely have some warranty left so why not head to the dealer?
Kurt
KassuX97
May 26, 2019 09:25 PM
tofuprod
Jan 28, 2019 06:58 AM
igorxx
Jan 18, 2014 04:56 PM
daveav8s
Jul 9, 2008 07:21 PM
shaitaan
Jun 21, 2006 09:41 PM
