Will those wheels fit? START HERE.
Old 04-14-10, 03:03 PM
  #1006
mercedessx
mercedessx's Avatar
Garsons fronts 18x9 et +6
Rears 18x10 et -6
I know they will go on my 240 but what about the Lexus ??
Old 04-14-10, 07:37 PM
  #1007
anonymous1
anonymous1's Avatar
Just a quick question - I just got my new wheels on the car: 19x8.5 Forgestar F14 with a +38 offset and 235/30/19 tire in front. I'm lowered with about a 1.5 finger gap in front. When I make a U-turn or hit a bump while making a sharp turn, I seem to get a little rubbing, is there anyway to prevent this from happening?
Thanks!
Old 04-15-10, 06:30 AM
  #1008
Chekmi21
Chekmi21's Avatar
Default Will these wheels fit my 2008 AWD IS250?
Hi Guys,
I have a 2008 AWD IS250 on stock suspension. I was wondering if these wheels will fit? I can get a full set with new tires for like $600, so I thought I'd give it a shot.
Wheels Specifications are:
18x8 on all four wheels
+30mm offset on all four wheels
225/45/18 Front Tires
245/45/18 Rear Tires
5x114.3 Bolt Pattern
66.1mm Bore
The only thing I could see being an issue is the difference in bore size, as I believe Lexus has a 60.1mm Bore? But I've seen people on the forum with Infiniti wheels so, were they using hubcentric rings?
Thanks
Old 04-15-10, 10:37 AM
  #1009
Chekmi21
Chekmi21's Avatar
Thanks for moving the post MODS, didn't realize this thread was here.
In addition to my bore question above, will the size of the tires work with AWD?
Old 04-15-10, 02:52 PM
  #1010
mercedessx
mercedessx's Avatar
Rears 18x10 et -6
Any ideas if these will fit
Old 04-15-10, 02:56 PM
  #1011
integlspwr
integlspwr's Avatar
im gonna have to say no..
i already have a 18x9.5 +12 225.40.18 on my car and the rears are super super flush and the fronts got poke.
Working on getting my fronts lower though by running a 215.35.18 on 9.5.
Old 04-15-10, 04:36 PM
  #1012
Mv350
Mv350's Avatar
they wont, go widebody tho, just so they do
Old 04-15-10, 04:39 PM
  #1013
Mv350
Mv350's Avatar
Originally Posted by Chekmi21
Hi Guys,
66.1mm Bore
Thanks
should fit without a problem, just get hubcentric rings
Old 04-18-10, 11:52 AM
  #1014
mercedessx
mercedessx's Avatar
19'' 10j wide rear wheels
19'' 9j wide front wheels
35 offset
How hard will it be too fit these sorry with all the questions and different fit ments
Old 04-18-10, 02:17 PM
  #1015
Sytfu_IS
Sytfu_IS's Avatar
35 offset
Front will fit with a 225/35 and rear will fit with 265/35 with a little bit of shaving or rolling unless you want to run 255/35 which will also work. If you're lowered that is.
Old 04-18-10, 03:22 PM
  #1016
steezy
steezy's Avatar
honestly, anything can fit with $$$$
Old 04-18-10, 04:54 PM
  #1017
Chekmi21
Chekmi21's Avatar
How do people fit Infiniti wheels when they have a 66.1mm bore and Lexus has a a 60.1mm bore?
Old 04-18-10, 05:10 PM
  #1018
javyLSU
2IS OG
javyLSU's Avatar
^By using a 66.1 to 60.1 hub centric ring.
Javier
Old 04-18-10, 05:23 PM
  #1019
6Sp33d
6Sp33d's Avatar
ive asked many times and have gotten all sorts of answers. figured id give it another shot.
19x8.5/10 +15,+20.
currently have 225/35 and 245/35
-2.2F -2.4R
front and rears rolled... still have major rubbing issues.
Old 04-18-10, 06:15 PM
  #1020
Chekmi21
Chekmi21's Avatar
Javier
Thanks Javier, can you recommend a brand or a place to get them?
Quick Reply: Will those wheels fit? START HERE.
