Will those wheels fit? START HERE.
Old Apr 4, 2012 | 11:24 PM
  #3361
DocFreud's Avatar
DocFreud
the 9.5 +35 will have only 2.7 mm more poke. so its pretty much the same.
Old Apr 5, 2012 | 03:06 AM
  #3362
Charizmo's Avatar
Charizmo
What Modifications I Gotta Do To Be Tucked Front And Rear?
Fronts: 20x9 +38 With Falken 245/30/20
Rears: 20x10.5 +45 With Falken 275/30/20
Or Any Suggestions On Other Tire Size I Should Run?
Old Apr 5, 2012 | 07:37 AM
  #3363
sick's Avatar
sick
Quick tire question. Will a 225/35/19 Front, 235/35/19 rear throw off the speedo? Sorry I didn't have time to search a whole lot.
Old Apr 5, 2012 | 09:49 AM
  #3364
DocFreud's Avatar
DocFreud
less then 1% i think
another question, i can't find the fender tab at my car. i thought its somewhere near the bumper?
i've seen the pic, that should explain where it is located, but my car looks different
Old Apr 5, 2012 | 10:20 AM
  #3365
projectdna's Avatar
projectdna
the bumper tab is farther up along the wheelwell edge.
it is (or, should be) where the fender sheetmetal and the bumper meets.
Old Apr 5, 2012 | 11:25 AM
  #3366
maximL's Avatar
maximL
How hard would it be to fit these: F: 19x9.5 +17 R: 19x10.5 +22
I'm assuming I would do 225/35/19 F and 245/35/19 R, does that sound right?
Roll (with natural pull) all around going to be enough?
Old Apr 5, 2012 | 11:29 AM
  #3367
steezy's Avatar
steezy
shouldnt be that hard. tires, yes with a roll and pull. shave that tab and know you fender liner will be gone.
Old Apr 5, 2012 | 11:48 AM
  #3368
maximL's Avatar
maximL
Am I looking at camber kits to fit these or natural camber?
Old Apr 5, 2012 | 11:52 AM
  #3369
DocFreud's Avatar
DocFreud
natural is enough if you go low.
Old Apr 5, 2012 | 12:31 PM
  #3370
maximL's Avatar
maximL
So I would have to completely remove the fender liner or there still a chance of modifying it?
Old Apr 5, 2012 | 02:45 PM
  #3371
Mv350's Avatar
Mv350
i left the front 6" of my fender liner to cover the wire loom for the foglights. the rest was cut out.
Old Apr 5, 2012 | 02:50 PM
  #3372
steezy's Avatar
steezy
I wouldnt recommend removing it completely maybe cut it or use a heat gun and push it as far back as you can. I may have exaggerated it. You'll be rubbing a lot. Most of us just keep rubbing and it'll eventually put holes in the liner. At that point you wont hear much rubbing anymore.
Old Apr 5, 2012 | 02:54 PM
  #3373
steezy's Avatar
steezy
Shoot i ran into new problem recently. My rear bumper tabs broke off and i found holes in rear liners.
Old Apr 5, 2012 | 05:17 PM
  #3374
Mv350's Avatar
Mv350
cut it all out, do i gotta post more pix
dont wory i broke mine off too
so i removed all the bs inside lol
Old Apr 5, 2012 | 06:36 PM
  #3375
laobo979's Avatar
laobo979
I'm still debating on tire size on my new setup
