DRL Question
Old Feb 23, 2010 | 02:19 PM
svntwosix's Avatar
svntwosix
Originally Posted by raptor22
twixx, do you have the 68 LED or the new 2x brighter 28 LED? From your thread and the pics, it looks like you have the 68 LED, but your v-leds link is to the new 28 LED version.
in any case, it seems v-leds might be discontinuing the 68 LED? since i can't find it on their website anymore, at least not the white ones.
NOTE: There are two different types of LED from v-leds being mentioned in this thread.
For those with the 68 LED from v-leds or similar LED from other brands, as twixx and xuningshen pointed out, installation is very easy, and no drilling, since all you need is the 9005 DRL module from v-leds, which fits inside the housing.
But svntwosix has the high power 28 LED, and v-leds suggests using an extra HID relay harness. I'm not sure how everything's hooked up, and i don't have these, but looks like the relay harness might be the reason why svntwosix said drilling is needed.
Yes, what raptor is saying is correct, I have the 28 LED Newer ones that you need to run the HID relay to it along with 1 of hte modules. If you guys read my post, you would've seen me say I want to exchange for the older 68 LED one, which you both are referring to. You have to drill a hole to put in the HID relay on both sides. AND you need to tap into the fuse box. Not worht the hassle for 2x brighter lights in the DRL. I would skip the bragging rights.
Old Feb 24, 2010 | 05:51 AM
twixx007's Avatar
twixx007
Sorry about that link. You're right. I have the 68 LED. Here is the correct linky to them.
Old Feb 24, 2010 | 04:56 PM
ssjnimma's Avatar
ssjnimma
anyone who is looking for the 68's since VLEDS is out of stock... I just picked up mine from here, which are in stock:
http://store.ijdmtoy.com/68-SMD-LED-...flux_sku45.htm
and go ahead and use the coupon code: gojdm for an extra 10% off!!
Old Feb 24, 2010 | 06:27 PM
DarkIs250's Avatar
DarkIs250
What about the DRL module?
Old Feb 25, 2010 | 05:44 AM
Tulsa1's Avatar
Tulsa1
You will need that if you don't want them to flicker in day mode.
Old Mar 14, 2010 | 10:54 AM
peterAP2's Avatar
peterAP2
so SMT SMD 68 LED HID requires the module to avoid flickering or only the 28 LED?
Old Mar 14, 2010 | 01:33 PM
ernestfyu's Avatar
ernestfyu
^ both of them require the module to avoid flickering. some people can endure the flickering though. it's only 10dollars, i would get it.
Old Mar 14, 2010 | 01:37 PM
L-S-D's Avatar
L-S-D
so anyways i currently have the SMD 18 LED which are super bright
i was wondering
is this the correct 68 led for the DRL
http://store.ijdmtoy.com/LED-Fog-Dri...9006_sku46.htm
which one of these
(aka HB4 or 9012)
aka HB3 or 9145
aka H8
Old Mar 14, 2010 | 01:45 PM
llamaboiz's Avatar
llamaboiz
you guys and your discoballs... heres what i use from ebay's warden_jp2002, had it for almost 3yrs now and no problems and no discoball *when on* and no yellow bug eyes *when off*, due to this type of LED the flicker makes it look like a mini HID so no relay for me
Old Mar 25, 2010 | 11:23 AM
arnelabano's Avatar
arnelabano
Can you post some pics? I want to see how bright these are compared to the discoball LEDs....lol
Old Mar 25, 2010 | 11:31 AM
revoappare's Avatar
revoappare
I got the same 9005 bulbs as llamma, and installed them yesterday. They definitely rock. Got them from warden jp as well. The best part, they don't cost as much as the vled bulbs, and you don't need a separate harness. Plus, most of us are just trying to get rid of the yellow.
Old Mar 25, 2010 | 11:36 AM
llamaboiz's Avatar
llamaboiz
Old Mar 31, 2010 | 12:30 AM
piracyinc's Avatar
piracyinc
I looked on Ebay for the mentioned seller, warden_jp2002, and the only LEDs I could find was HB4/9006 Fog Lamp 1W High Power LED bulb..will these work for the DRLs? He did not have any auctions for HB3/9005 like the one llamaboiz mentioned.
Old Mar 31, 2010 | 12:32 AM
piracyinc's Avatar
piracyinc
Hey one more thing, llamaboiz, do Hawaii plates have that American flag on them or is that another "mod"? l like it
Old Mar 31, 2010 | 12:41 AM
TinCan's Avatar
TinCan
So how does the dealership turn the DRL's off? and can I do that without going to them?
