my left headlight went out... grrr.
Old 02-09-10, 08:30 PM
s6 4rings
s6 4rings's Avatar
I noticed my right side was out the other night too. Will the dealer automatically replace both for uniformity, or just one side?
Old 02-09-10, 08:41 PM
projectdna
projectdna's Avatar
Originally Posted by eframsal
but if it's the bulbs why do they light up fine prior to starting the engine. Only when I put it in gear does the light go off.
since i'm not intimately aware of how automotive HID lighting systems work, i'll direct you to something i found on howstuffworks.com (the internet is your friend):
In off-road and regular circles, HID lights are becoming popular. HID stands for "high-intensity discharge" and refers to a high-voltage transformer that sends extremely high voltage to electrodes inside the bulb. This causes an arc, which ignites a mixture of xenon gas, mercury and metal halides inside the bulb. The resulting light is brighter and whiter than the light of an ordinary lamp. Check the lights before adding them to your vehicle. Some may not be legal for use on regular roads.
so in your case, my guess is that not enough electrical power is going to the OEM HID lighting system to keep the HID bulbs "fired up". that is why bulbs will flicker and/or shut off moments after the engine starts.
Old 02-09-10, 08:45 PM
projectdna
projectdna's Avatar
my guess is that the dealer will replace only the defective side, logic being that they're not going to replace something that's working fine.
Old 02-09-10, 08:48 PM
s6 4rings
s6 4rings's Avatar
in three years it went out 2 weeks ago, and hasn't since.
Old 02-09-10, 08:51 PM
projectdna
projectdna's Avatar
my understanding of lexus dealerships performing warranty repair work is that if they can't duplicate the problem, they won't fix it. YMMV.
Old 02-09-10, 09:05 PM
IAMJAVEDG
IAMJAVEDG's Avatar
they need to recall this bull ***** happend to me TWICE I'm tired of changing headlamps. I'm currently looking for one... since one of my tabs is broken the dealer refuses to warranty it.
Old 02-09-10, 11:44 PM
DailyDrive
DailyDrive's Avatar
1-2 years of owning my car, my left side bulb went out three times... and the dealer replaced it everytime for free. the car was still under warranty of course... my service service advisor told me if i had to bring it back again they would look more into and maybe replace the ballast.. two years later it hasn't gone out since.
Old 02-10-10, 01:13 AM
ilv1004s
ilv1004s's Avatar
man so much problems...
we dont have any of those problems in RHD cars
Old 02-16-10, 12:34 PM
NeverSatisfied
NeverSatisfied's Avatar
Originally Posted by allst4r
any suggestions on bulbs? ok i need to look into that,.im going to call the dealer tomorrow. ill let you guys know if its covered. i believe the bumber to bumber is 3 years 36k miles,
What did the dealer say?
Old 02-17-10, 03:55 PM
xerxes717
xerxes717's Avatar
Man I wish I had seen this thread before posting mine: https://www.clublexus.com/forums/is-...t-stay-on.html
Same thing happened to me (except on the passenger side), i haven't been able to replace my bulb yet though.
Old 05-05-10, 05:07 AM
NeverSatisfied
Driver's side light went out again about a month ago, so I took it into the dealer. They swapped sides (bulbs) to see if it's the bulb or something else. A GS owner came in for the same prob and they did the same thing. No probs so far.
Old 05-05-10, 08:22 AM
IAMJAVEDG
IAMJAVEDG's Avatar
I have had this problem happen to me 3 times already and had to replace the headlamps due to broken tabs (dealer wouldn't warranty them) lexus should fix this issue...
Old 11-12-10, 08:53 AM
isthrizzy
isthrizzy's Avatar
OK, so last night I noticed my driver's headlight was out. When I switch the lights on, it stays on momentarily (maybe 5 seconds), then shuts off. This is something you can repeat over and over.
If the bulb was dead, wouldn't it just flat out not work?
My car is an 06 with 63k on it, but I did buy an extended warranty. I'm not sure that the extended warranty would cover this. Any thoughts? Where's the best place to buy a replacement bulb? (I'm sure it's not the dealer)
Old 11-12-10, 08:54 AM
isthrizzy
isthrizzy's Avatar
Also, forgot to mention, there is no warning indicator that comes on the dash. Shouldn't the car alert you to the fact that a bulb is out?
Old 11-19-10, 01:27 PM
PJIS
PJIS's Avatar
Default Headlight bulb
Hi guys, would anyone know of a quick way of replacing the d4s bulbs. Thanks i would greatly appreciate your reply.
Quick Reply: my left headlight went out... grrr.
