help with is350 offsets
Old Nov 30, 2009 | 08:47 PM
2slow's Avatar
2slow
Default help with is350 offsets
Don't tell me to post this in tires/wheel section because there's no feedback and no one knows better offsets then members in the 2is.
So i have a is350 on eibach 250 springs. I'm getting a set of AME fs-01 but i have no clue about offsets. I got the offset calculator and played around with it, but i'm not sure if the offsets i want will rub. These are the 2 choices
18x9 +25 18x10 +25 OR 18x8.5 +48 18x9 +31
With the top 2 offsets, how big of tires can i squeeze in without rubbing.
I guess the rear i'd want to get as wide as possible with rubbing on bumps.
And the front i still want to have a nice turn ratio.
Thanks i advance.
Old Nov 30, 2009 | 09:15 PM
aliu603's Avatar
aliu603
hmm why not go 19s?? just wondering
Old Nov 30, 2009 | 10:35 PM
2slow's Avatar
2slow
Cause i'm getting a deal on 18s.
Old Nov 30, 2009 | 11:07 PM
breplica's Avatar
breplica
Thanks i advance.
JMHO
The first 2 you listed will definitely rub. The second 2 you listed should not rub. but the front +48 will probably be a little too sunken.
Old Dec 1, 2009 | 12:37 AM
llamaboiz's Avatar
llamaboiz
what tire size will you run? vip stretch or NASCAR big tire? also dont forget to make sure the front rims are High disk (R disk).
imo, save up for 19"
Old Dec 1, 2009 | 12:56 AM
2slow's Avatar
2slow
What's R disk? I want the big tires in the rear. Front tires can be the smallest that will fit on the rim.
Originally Posted by breplica
JMHO
If it's sunken i guess i can put it out with some spacers.
lexusis13
Jun 21, 2012 03:20 PM
efdrums
Dec 28, 2010 05:55 AM
JDMxIS2G
Wheels, Tires & Brakes Forum
Feb 20, 2010 05:04 AM
Tree Fiddy
Mar 28, 2009 06:59 PM
