Help?!?!?! (Rough idle after intake install)
Old Oct 30, 2009 | 01:37 AM
cupid0210's Avatar
cupid0210
Default Help?!?!?! (Rough idle after intake install)
Okay,I just installed an LMS intake and a JUN-TW Sway bar on my car. I followed all of the directions and it seems to work. The power output to me is a SIGNIFICANT difference, i feel the power and hear it as well!! The only problem i have is that the idle is more rough. To me, its a bit too rough. My car never shook before i added this. Is this normal???? Also, i installed the front sway bar, but for some reason the lexus covers wont fit on my car, what is going on?? Can anyone help me????
Old Oct 30, 2009 | 12:52 PM
javyLSU's Avatar
javyLSU
2IS OG
Has your idling problem gone away? I've noticed that anytime I've done anything that involves unplugging the MAF sensor it takes the car a little while to return to normal idling. And let me make sure I understand you - you bought a front SWAY bar that's interering with the engine covers? Are you sure you're not talking about a shock tower, or "strut bar" as JUN-TW refers to it?
Javier
Old Oct 30, 2009 | 05:54 PM
cupid0210's Avatar
cupid0210
its that EXACT same thing you have in the picture, whenever I put that on, NONE of the covers fit anymore.
Old Oct 30, 2009 | 08:21 PM
Kurtz's Avatar
Kurtz
That's not a sway bar, it's a strut tower brace (which is especially funny going on a car that doesn't even have struts) but I'm not sure the engine covers are supposed to fit over it anyway.
Old Oct 31, 2009 | 11:22 AM
juice14's Avatar
juice14
how old are your spark plugs?
maybe give it a Week to let the ECU do its thing. On my pathfinder after installing the Intake it would stall on cold days, and about 3-4 weeks it never did it again
Old Oct 31, 2009 | 02:19 PM
Koz's Avatar
Koz
Check all the clamps for tightness. Any air leaking in will cause problems.
Koz
Cr4zyfunny
CT 200h Model (2011-2017)
Feb 6, 2024 01:59 PM
delta901
Oct 6, 2008 11:52 PM
Suneet
Jul 27, 2006 10:59 PM
Shinchan
Suspension and Brakes
13
Aug 30, 2001 08:13 AM
CJGS4
May 2, 2001 12:18 PM
