NAV Disc 5.1 Problems
Okay so I tried to upgrade my nav disc and it was complete FAIL. So i try to insert my old NAV Disc and still the ultimate FAIL. I've removed the TV1 fuse, battery, removed the disc and everything still nothing only thing I'm getting or the these stupid pop ups. I think Im going to have to go the dealer on this one. Any advice.
Ive tried to refresh in Diag. Ive tried to clear the codes and memory, still Nothing. My next step is to copy the disc. Any advice.
Problem resolved, for anyone else that tries to upgrade their nav disk, food for thought DON'T DO IT. I simply burned the original nav disk to DVD+R+SL and inserted it into the drive. For some odd reason the drive started uploading this disk and not the OEM, kind of weird. After it loaded the disk and the setup, etc. I switched back to the OEM disk and have had no problems since.
Did you (or the previous owner, if you bought the car used) have the "Navigation shows car in wrong location" TSIB performed? If so, you got an updated version of the 5.1 software with the override feature removed. If not, the sequence is Menu, Volume, top left, bottom left, top left, bottom left, then press and hold override.
