Front wheel Rub!!
Old May 30, 2009 | 08:09 AM
g_abac's Avatar
g_abac
Default Front wheel Rub!!
I replace my IS250 RWD 2008 with F-Sport 18"x8" (40mm) with 235/40/R18
Normal turn and u-turn was normally. But when I turn left or right with fast speed, they gonna little sound of rub on front wheel. So, they are normally or not?
For the rear wheel, I also run it by F-Sport 18"x8" (40mm) with 235/40/R18 and using Ibachi V2 15mm spacer.
The factory recommend 225/40/R18 but GOODYEAR RS-SPORT was available only 235/40/R18.
So, how can I solve this problem or just let it pass?
Old May 30, 2009 | 08:29 AM
love67's Avatar
love67
you need to see where is it rubbing...if is it pastic, you can use heat gun to heat up the pastic then push the pastic back, so when you turn it won't rub it. but i think you are ok..if you just leave it.
Old May 30, 2009 | 09:05 AM
stooky's Avatar
stooky
^^ agree agree but if its really bothering you just run thinner tires but i really dont see how youre rubbing with those offsets..
Old May 30, 2009 | 09:16 AM
g_abac's Avatar
g_abac
Yeah. But just change this new set of tires. So, at here to run a new tires will cost around $240 per wheel.
GOODYEAR RS-SPORT that I using was not available with 225/40/R18. So,just change the front wheel to other model and leave the rear wheel with GOODYEAR RS-SPORT 235/40/R18 will work? Or I should change all wheels to the same tire?
http://www.youtube.com/watch?v=1BDcti6r70M
Attached Thumbnails Front wheel Rub!!-dsc02622.jpg   Front wheel Rub!!-eagle-rs-sport-size.jpg
Old May 30, 2009 | 09:26 AM
VIS250P's Avatar
VIS250P
235/40/R18
DING DING!!! U need possible like 225
Old May 30, 2009 | 04:38 PM
juice14's Avatar
juice14
if its just the plastic that is rubbing.... get a heat gun, heat the part where is rubbing and heat it to where it gets soft, then quickly push it in and you are set
CDNX
NX - 1st Gen (2015-2021)
Jan 29, 2019 10:06 PM
Marko1973
Apr 17, 2018 11:09 AM
is250fsprt
Oct 15, 2013 03:53 AM
g_abac
Mar 2, 2009 10:51 AM
Osiris_x11
Wheels, Tires & Brakes Forum
Apr 20, 2008 04:26 PM
