Sorry another oil question
Old May 8, 2009 | 10:03 PM
PureCrstal's Avatar
PureCrstal
Default Sorry another oil question
Hey guys sorry for this same topic but I couldn'tfind my answer on the search. So it's time to do my regular oil change and went to go buy my mobil 1 5w-30 but couldn't find any so I bought the mobil 1 0w-30 advanced fuel economy instead. I was wondering if this is the same thing and if it is safe to use. It says it outperforms a 5w-30 but wanted to hear ur guys' opinion first. TIA
Old May 8, 2009 | 10:54 PM
airwrench's Avatar
airwrench
Warning: Your going to get 20 different answers and everybody knows best lol! My opinion, try for a 5w oil, its better for the warmer weather at engine start. If you cant find anything, just use what you have. I wouldnt sweat it.
Old May 8, 2009 | 11:15 PM
Infra's Avatar
Infra
It won't make any difference. The first number describes viscosity at cold conditions. At engine operating temperature, both oils will perform the same.
You don't drive hard until your engine is up to operating temperature anyways, right? RIGHT?
Since there is not a mineral oil grade of 0W-xx, it's typically not manufacturer recommended.
Old May 8, 2009 | 11:25 PM
joeker's Avatar
joeker
according to the manual, 10w-30 is acceptable as well, but 5w-30 is recommended for cold/warm starts
Old May 9, 2009 | 09:31 AM
Bichon's Avatar
Bichon
Not quite, the manual discourages the use of 10W-30, says it's okay if nothing else is available, but to switch it out at the next change.
Per a TSIB that was released after the manual was printed, the recommended viscosity (and the factory fill) for the 2IS is 5W20. 5W30 is also perfectly acceptable.
Old May 10, 2009 | 07:32 AM
Koz's Avatar
Koz
Anything from 0w-20 to 10w-30 will work fine. 0w-30 is better then 5/10w-30. It will give you better cold start flow. 0w-20 is even better, since 5w-20 is the recommended weight.
Koz
Gil Smash
Jun 1, 2012 11:28 PM
SC_SHAWTY
Aug 26, 2010 02:11 PM
Slvr surfr
Dec 23, 2009 07:34 PM
ILOVEGIRLS
Mar 25, 2006 06:28 PM
simonsays
Maintenance
19
Sep 28, 2005 03:24 PM
