Interior Dome Lights swap
Old May 5, 2009 | 03:40 PM
SM_BlckIS's Avatar
SM_BlckIS
I tried doing the same thing but was unsuccessful. Instead, I used a very small screw driver and slowly pry the dome lens cover off. If you look at the lens cover closely, there are some gaps for a small screw driver and it just pop out. After the cover off, replacing the bulbs was easy.
Old May 5, 2009 | 08:04 PM
jc86's Avatar
jc86
in the back yes - this is exactly what you do
but in the front - there are no little gaps unless you are talking about under the door and on/off buttons... i tried putting an exato knife up there and it snapped when i tried to pull it down hah -_-
Old May 7, 2009 | 12:57 AM
MRTUND350's Avatar
MRTUND350
Use a plastic pry tool, you can pick them up at your local body and paint supply shop, or get a plastic scraper tool, something thin with a bit of rigidity. Don't use a screwdriver, you will dent the surrounding plastic.
es99300
Jun 29, 2022 12:57 AM
qurious
CT 200h Model (2011-2017)
Jan 7, 2019 10:58 AM
rebecca350
RC - 1st Gen (2015-present)
Mar 30, 2016 02:37 PM
homoonar
HS 250h Model (2010-2012)
Sep 9, 2013 06:55 AM
