Daytime light question
Old Mar 17, 2009 | 04:27 PM
jns350's Avatar
jns350
Originally Posted by iLexi
I'm just really confused bc when I put the LEDs with the module it didn't work. Only the high beams worked but the drl lights didn't turn on
Just to clarifiy..are you sure that your Lexus personal settings isn't set to "DRL off" from when you got your car. If no..then you might have a pass through from your module. By means that the module will get a input voltage around 3.5v in DRL mode then up convert to 14v alternator voltage. When you use your high beams then you place 12v past the module. Then you have a defective module
Old Mar 17, 2009 | 06:43 PM
llamaboiz's Avatar
llamaboiz
listen up ppl, if you want to see your drl on, goto your car, start it up, take off the ebrake, put the car in drive than back in park (not really needed but just do it), get out and look at the front of the car, dont matter if the lites are on auto or not. When your done get back in your car and turn it off...
and imo those yellow bug eye drls (some call it disco ***** ) are ugly
these are class
Old Mar 17, 2009 | 08:27 PM
09 LEX 250's Avatar
09 LEX 250
Originally Posted by xjayho
i live in virginia and plan on changing my daytime running lights to blue LED. Can i get pulled over for this?
please answer your own question
Old Mar 18, 2009 | 04:45 AM
tex2670's Avatar
tex2670
There's no LPS for the DRL. You *may* be able to convince the service manager to turn them off, but not all dealers will do it.
Old Mar 18, 2009 | 06:02 AM
T4styPh0's Avatar
T4styPh0
DRL is in the LPS settings but its not on the little sheet they give you, it's hidden. Had mine turned off yesterday and they did it with no hesitation, but like you said it's up to the dealer though. Lobuxracer posted a complete listing a while back.
https://www.clublexus.com/forums/att...ttings-rev.pdf
Old Mar 18, 2009 | 06:52 AM
tex2670's Avatar
tex2670
Yes--we are saying the same thing. The "LPS" are those items listed on the official sheet. But, the DRL and other items can also be manipulated by the dealer--not all dealers will turn off the DRL, but every dealer WILL set your LPS.
TLRD
May 31, 2013 05:45 AM
captaincru
Apr 25, 2012 02:53 PM
Yuri101
Mar 25, 2012 09:54 AM
YellowRock
Lighting
Jan 21, 2003 01:46 PM
