Horrible camber issues (Pics)
I have the exact same problem. The front tires are the worse. The inner and outer tires on both fronts are worn out, but the middle is still ok--but experiencing normal wear regardless. So from what everyone's saying, an alignment and toe adjustment is necessary?
How often do you have to get it aligned like this?
Check to see if your car is part of the campaign for the steering linkage. They are supposed to do an alignment after replacing it. I am not sure if my dealer did the alignment since he told me that I needed to replace my tires and should get and alignment after that. I challenge him on it since he told me that an alignment would be done after the steering campaign. My tires are also worn on the inside and I have 24k miles and I push the limit on my air pressure. These low profile tires ride to much on the edges and I have heard that toe in helps in quicker handling.
These "low profile tires" don't ride anymore on the edges than any other tire, but you do need to put enough pressure in them so they don't wear out the edges first. ALL tires will wear out their edges first if they are underinflated.
