run 350Z setup of IS350 works?
Old 01-19-09, 10:42 AM
AK-47
AK-47's Avatar
Default run 350Z setup of IS350 works?
is there any chance of running 350Z or G35 setup on IS350? with stock setup (not lower at all)
9.5 and 10.5
+22 all around.
would the wheel stick out of fenders?
and what tires size would work best?
without any rubbing!!!!!!!!!!!!!!!!!!!!!
Old 01-19-09, 02:36 PM
ChrISF
ChrISF's Avatar
won't work without rubbing issues...i've tried.
Old 01-19-09, 07:43 PM
iSuxeL
iSuxeL's Avatar
You can if it was 8.5 & 9.5
Old 01-19-09, 07:56 PM
mikez
mikez's Avatar
8.5 and 9.5 running +22 all around would be too conservative for 350z and G35, wouldnt be called 350z setup anymore
Old 01-19-09, 08:10 PM
flowrider
flowrider's Avatar
Received 1,835 Likes on 1,296 Posts
^^^^I had a G35 Coupe with 8.5/9.5 and ran +25 in front and +30 in back. Not to conservative for me. It was just right.
Lou
Old 01-19-09, 08:25 PM
iSuxeL
iSuxeL's Avatar
I was talking about for us
Old 01-19-09, 08:35 PM
Tablist06
Tablist06's Avatar
Those sizes would work if you are not lowered at all. It will rub in the front, and it will also stick out of the body. Other than that it should fit.
Stretch the tires and slam the car, then you'll be flush.
Old 01-19-09, 09:05 PM
VIS250P
VIS250P's Avatar
Hell yea I agree
Old 01-19-09, 09:22 PM
ChrISF
ChrISF's Avatar
Originally Posted by VIS250P
Hell yea I agree
Word..........
Old 01-20-09, 05:48 AM
acefalcon2
acefalcon2's Avatar
hahahha ive tried using8.5"+36 and 9" +26 if that helps is a conservative nissan setup
Old 01-29-09, 11:22 AM
AK-47
AK-47's Avatar
what about 9 front and 10 rear, +22 all aroundÉ this is more like GS setting.
Old 01-29-09, 12:00 PM
t0e
t0e's Avatar
^ if you stretch the tires ya!
Old 01-29-09, 02:56 PM
2SwiFt29
2SwiFt29's Avatar
i'm running 8.5 front and 9.5 rear.. my front rubs on a sharp turn or running over slight bumps on the freeway.. previously when I was running Nitto 555s with 265 rear, it was rubbing when my car was packed.. switched to 265 and no rubbing issues.. now i switched to the Nitto Invo and back to 275 with no rubbing issues with passengers.. for me, it depends on the type of tires, but the Invo has a thinner sidewall so thus no issues with rubbing on the rear.. however, front rubs when it turns still..
akafixture
11-08-15 01:43 PM
DplanDman8
04-12-13 03:42 AM
kim0217
01-09-12 03:50 PM
JohnGS4
10-04-06 07:41 PM
BadBtsz4u
Wheels, Tires & Brakes Forum
05-21-02 08:01 PM
Quick Reply: run 350Z setup of IS350 works?
