sound problem
Old Jan 11, 2009 | 09:45 PM
nnh768's Avatar
nnh768
Default sound problem
Hi all,
My radio sound on the passenger side is going low and high intermittently. This only happens when the radio or CD is on, but not when i use the vaistech SLI. could it be the vaistech harness?
Thank you
Old Jan 12, 2009 | 06:57 AM
db6's Avatar
db6
Default I had the same problem, but it was the drivers side -
I had had the unit installed by someone else because I couldn't get the AC vents out. Since having the issue I decided I would check it myself. Whe I got the radio out I saw that the vaistech connection into the back of the headunit was loose. I plugged it in the whole way, made sure it was tight, and haven't had a problem since.
Old Jan 12, 2009 | 07:15 AM
nnh768's Avatar
nnh768
i'll try that, thanks
galtom
RX - 1st Gen (1999-2003)
Jun 30, 2018 09:40 PM
sankids
Jun 5, 2017 07:11 PM
WHY1
Jun 22, 2015 11:17 AM
427cobra
Oct 29, 2014 08:33 AM
loccsta187
Dec 16, 2011 07:07 AM
