Removing Headlights or Bumper To Install Aftermarket HIDs?
Old 04-27-08, 10:02 PM
PCP20
PCP20's Avatar
Default Removing Headlights or Bumper To Install Aftermarket HIDs?
Are there any guides for removing the headlight assembly or bumper to install new HID bulbs?
Thanks
Old 04-27-08, 10:07 PM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
Theres no need to remove the bumper or headlights. Search the forums.
Old 04-27-08, 11:36 PM
radicalrev
radicalrev's Avatar
you need to remove the bumper tho when you install HID for the FOGS
Old 04-27-08, 11:52 PM
2slow
2slow's Avatar
Not if you go through the fender.
Old 04-28-08, 12:03 AM
ISCjonny
ISCjonny's Avatar
NO need to remove headlight for low-beam HID install.. yea.. u can go thru the fender lining for the FOG HID.. but its a pain in the ... your better off takin the front bumper off, that way u easily mount ur ballast to a secure location.
Old 04-28-08, 12:05 AM
radicalrev
radicalrev's Avatar
oh so you can place the HID just inside the fender (in front of the tires) ??
didnt know that...that would be so easy to install the HID then...so if anything goes wrong you dont have to remove the bumper..
Old 04-28-08, 06:56 AM
Brian231
Brian231's Avatar
No need to remove the bumper for install of both low beam and fogs. it does make things easier to work with for the fogs, but you can remove the front wheels and go via the fender wall. The ballasts are important to secure and mount so they do not bounce around and burn out. Anyone can PM me if they need assistance.
Old 04-28-08, 12:57 PM
stvn
stvn's Avatar
much easier to remove the front bumper than to try and go through the fender walls. plus you can mount the ballast securely. nothing that hasn't been said before. just keep an eye on all the screws because i lost a couple. anyone know where i can get some extra ones (the ones that secure the lip and bumper)
Old 04-28-08, 01:04 PM
Brian231
Brian231's Avatar
Those little screws are easy to loose, you should go to the bulk screw area of Home Depot, Lowes, Menards etc and simply buy a bunch in different sizes for under a buck or remove a good one and bring it in. Make sure to check your install area so you don't run over one of the lost screws.
Old 04-28-08, 01:55 PM
radicalrev
radicalrev's Avatar
brian any pics of where you mount the ballast from the fender wall??
btw the method is the same as this right?
https://www.clublexus.com/forums/sho...d.php?t=223728
and is it inside there that you place the Ballast?
Old 04-28-08, 05:26 PM
iKenn
iKenn's Avatar
This thread has turned, haha
I think he just means the low beams since he asked about how to change the bulbs.
Old 03-26-10, 06:59 AM
Brian231
Brian231's Avatar
I wanted to re-vamp this thread as I have received two emails this past month on this topic and hoped to inspire more confidence in this avenue.
This is going back two years, but I remember we removed the front wheels (one side at a time), removed the plastic clips that hold the wheel well plastic in place, and pulled back. After that, it is not too bad. Removing the wheel is key. If you remove the front bumper like some, it is very very hard to re-install and usually needs two people. Once you peel back the black plastic from the bumper, you will see the plastic fog light housing. Simply unconnect the bulb harness and twist bulb out. Then install HID bulb and make sure it it tight. Some cheaper bulbs wiggle and can produce moisture in the housing. Once this is done, mount the ballast securely with zip ties, their is an area I remember on top of the fog housing to simple double up two zip ties and secure. Then run the wires up to engine compartment and you may want to also secure wire with zip ties to non hot surface and away from drive belt area.
Old 03-26-10, 01:29 PM
Tchan1
Tchan1's Avatar
Don't take the easy way out by going through the fender and later on have problems occur. Just take the bumper off and do the install from there. If you're going to do it, do it right the first time. Btw it doesn't take two people to put the bumper back on.
Old 03-26-10, 02:37 PM
iSuxeL
iSuxeL's Avatar
Wow are some of you serious?! LOL TAKE OFF THE BUMPER MAN! It's soo much easier and a lot less aggravating. There are spots to mount the ballast which you can only see once the bumper is removed.
Old 03-26-10, 04:13 PM
javyLSU
2IS OG
javyLSU's Avatar
Javier
IS250chino
11-09-12 11:31 AM
Vibes63
06-20-12 11:14 AM
TwentyTen
01-25-10 04:11 PM
w1ck3d64
08-02-08 09:25 PM
Rich27
Lighting
03-19-04 09:15 PM
Quick Reply: Removing Headlights or Bumper To Install Aftermarket HIDs?
