Quote:
The only interface that we have for park assist is the < o > buttons on the side of the dash. And, the only option it seems to give is the on/off capability, and I think hitting the info button on the steering wheel in this screen just cancels out the < o > display.
Maybe one of the Lexus Tech's on the forum can help us out.
when you press the info does it go thru the different features like telephone (for setup) and other features? If so then I would think you select the Park Assist and then it should allow you to adjust. its got to be in the same place as where you adjust the sensitivity in the non navi units.Originally Posted by mikes rx
I honestly wouldn't know where to start. The only INFO button we have is the same one that everyone has, which is the button on the steering wheel for the dash display.The only interface that we have for park assist is the < o > buttons on the side of the dash. And, the only option it seems to give is the on/off capability, and I think hitting the info button on the steering wheel in this screen just cancels out the < o > display.
Quote:
There is no bluetooth with the non-nav. The info button on the steering wheel is the same as what you should have, where it scrolls through the MPG, avg MPG, temp, range, etc. There's no other options to fiddle with, except using the < o > buttons on the side of the dash, which should also do the same as yours (speed light, tach light, TPMS selector).Originally Posted by passnu2
Non-nav's only have the small LCD screen in between the tach and speedo for options, and I think all IS's (whether or not they are equipped with nav), show the same controls there.
I don't even know of a way to adjust the sensitivity of the PA in non-nav.
