IS250 AWD wheels pics request
Old Mar 5, 2008 | 09:50 PM
dannygjatt's Avatar
dannygjatt
Default IS250 AWD wheels pics request
I want to see some AWD's with OEM chrome 17" or anything else, I am planning on getting rims really soon i want to see what everyone has.
show me what u got guys!!
Old Mar 6, 2008 | 07:10 AM
Brian231's Avatar
Brian231
You can get much nicer wheels at a much cheaper price if you stick aftermarket. Just make sure all the wheels are the same size with AWD or you will cause damage to the drivetrain over time. OEM wheels at Lexus start at $500+ without center caps. That is way too much money for one wheel. Try Discount Tire, they can usually obtain most rims.
Old Mar 6, 2008 | 09:25 AM
Electric's Avatar
Electric
You actually can run a staggered setup on an AWD if youd like, you just have to get different tire sidewall heights for the front and back. You can look at tireracks website and check out the tire diameter.
If you try and buy 275/30/19 for the rear and 245/35/19 for the back, the back wheels will indeed be larger in diameter, however, if you get 245/40/19 in front, you can check the tire diameter and it should match almost perfectly (less than 0.5"inch) to the tire diameter of the rear set. If you dont do this though, yes you can damage the drivetrain!
Old Mar 6, 2008 | 09:43 AM
Brian231's Avatar
Brian231
Yes,
This is always true with playing with tire sizes, but when it comes time to rotate the tires to increase tire life due to more even wear, this is where you will run into issues. Not worth it IMO.
Old Mar 6, 2008 | 09:59 AM
Big Willy's Avatar
Big Willy
19 x 8.5
19 x 9.5
Old Mar 6, 2008 | 10:09 AM
Electric's Avatar
Electric
Yes,
Well to some, it is worth it. Some love that fat tire look in the back
xxxt
Aug 8, 2018 06:49 AM
aespinalIS
Build Threads
Jun 26, 2015 10:10 AM
bmaez
Oct 24, 2011 08:01 AM
dania
Aug 6, 2008 01:24 PM
Daisy1
May 30, 2007 10:31 PM
