IS 350 Range Approx.
Old Dec 27, 2007 | 08:41 AM
NovaIS350's Avatar
NovaIS350
Originally Posted by Shoganai
I get about 315 - 350 miles per tank depending on my driving conditions. I usually fill up within the 0-34 warning miles to empty indicator w/ Chevron.
Just got this email on Tips on Pumping gas:
I don't know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon. But my line of work is in petroleum for about 31 years now, so here are
some tricks to get more of your money's worth for every gallon..
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline,
regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations
have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity
and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role. A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature
compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3)
stages: low, middle, and high. In slow mode you should be pumping on
low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapor. Those vapors are being
sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you
have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation.
Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the
storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom.
Hope this will help you get the most value for your money.
DO SHARE THESE TIPS WITH OTHERS!
Holy crap brosef, thanks for the tips, I will definitely share this with all of my friends, even though they will think I am a huge geek.
Old Dec 27, 2007 | 02:19 PM
Sarorn's Avatar
Sarorn
Thanks for sharing Shogania! I never knew this before...and I will definately be sharing!
Old Dec 27, 2007 | 06:21 PM
Audiofan2's Avatar
Audiofan2
I mentioned on a previous post that 10% ethanol seems to give me about 5 mpg less. My range on without an ethanol additive is about 395 mi. I did notice that on a recent trip I got about 445 mi. when the car predicted 395 mi. based off of my previous driving. So I think on an IS350 with a full, completely topped off tank, gas put in the car during the morning, run down to where the light was on for about 20 miles, you should get as much as 450 mi. on the freeway @ 70 MPH.
Old Dec 28, 2007 | 12:30 PM
kschawaii's Avatar
kschawaii
WTF?!?! I'm getting 250-265??? I live in hawaii and i usually do city driving rather than freeway but could that affect it that much???
Oh and in a recent thread someone posted this...
http://www.roadandtrack.com/assets/d...d/02073car.pdf
and it says that the fuel capacity is 17.1 gal???? mine is 15... ????
fmm009
Maintenance
Apr 4, 2016 08:31 AM
TLPLEXUS
Oct 21, 2015 07:25 AM
Egone
Mar 21, 2013 08:00 AM
SC3005SPD1
Jun 23, 2005 07:21 PM
JohnsRX
RX - 1st Gen (1999-2003)
14
Oct 15, 2004 08:28 PM
