Last edit by: IB Advertising
Browse all: Interior
- How to Install XM Satellite Radio
Step by step instructions for do-it-yourself repairs
DIY: 2007 ISX50 OEM XM Satellite Radio Install
#76
I put it behind the glass on the inside corner (I'm guessing this is what you mean by parcel tray) and I'm getting the signal coming in and out more than I'd like. Just driving down a tree lined street drops out signal, where my dad and brother don't have this problem. I like the idea of the corner of the glass, I'll have to re-position it there tomorrow. Unfortunately I have to take apart everything to change the antenna location
I was worried it wouldn't work behind the tinted windows, but the guy at Lexus said that's where they normally install, so it shouldn't be a problem, I should have known better.
#77
I repositioned the antenna to the outside corner of the glass and reception is alot better. Driving down my street yesterday caused the signal to cut out 5-6 times. I drove down the street this morning at like 5mph (the neighbors must have thought I'm nuts) and it didn't cut out at all.
#78
Been driving around for a couple days and I've only had the signal cut out briefly twice. I was even able to drive around downtown Los Angeles and through a couple tunnels on the freeway without losing signal! Thanks to Mike for the suggestion of placing the antenna on the outside glass and to Ben for the detailed installation instructions.
#83
I use "..." ....... a lot
Offset to the right, it seems more stealth-like. Not many people expect a satellite antenna in the corner, so the obvious factor isn't there. I think it looks more like a GPS antenna or something else, rather than satellite radio. Also, with the antenna in the corner, it is surrounded on 3 sides by metal, which helps with signal reception, as it's technically supposed to be completely surrounded with metal.
Honestly, I was not expecting the antenna to work so well in the corner there, since it wasn't directly attached to metal. But, it works flawlessly (knock-wood), and is much more easily removable if needed. Also, it won't scratch up the paint this way. Just thank Lexus for having a recessed rear window.
#84
#86
Great intructions and pictures Big KUDOS Ben R!
Just got a question. I have the 08 IS350 and wondering if I installed the XM and activate the Real time Traffic will that show on my NAV screen? Has anyone subscibed to XM for the real time traffic? Any feedback will be appreciated.
#87
I just installed my XM on my 2007 IS250. It was a pretty easy install. The only problem I had was getting that right carpeted panel nice a flush. At first I used those plastic tie wraps but then I didnt use them because I had to tuck in those wires inorder to get that right panel flush.
I got my 8 digit code but when I try to register it on the XM site it doesnt recognize it?? Anyone else have trouble with it??
#88
No, I dont think any car comes from the factory with the sat tuner installed. It was more than likely installed by the dealer and yes you did pay for it somewhere... I had an 03 accord and it to was "XM Ready" but I still would have had to buy the tuner.
Our cars unfortunately do not support the XM Real Time Traffic feature. Currently the only Lexus that does is the LS.
Make sure you didnt mistake any of the zeros for the letter O. From the xmradio.com website:
Please note, the ID does Not contain the following letters:
"I" (eye), "O" (oh), "S," or "F"
#89
XM doesn't work anymore! Just says LOADING!
Hey guys,
I am hoping someone can help me. I posted a while back in this thread about my xm not working about 2-3 weeks after installing it, and after finally getting back into the trunk to get the the tuner and tinkering with it (a month and a half later), it still doesn't work!
(As fas as what I did with the tuner, I tried disconnecting and reconnecting the wires.)
When I turn on the st radio it gives me a LOADING text, and soon doesnt do anything at all...and locks up (as in, I cant even switch to a diff channel). If I put it on channel zero I still get the radio id, so I presume it is slightly working, but I get no audio.
I tried refreshing the radio via internet and customer care, and still got nothing.
Any ideas?
Should I have lexus look at it?
Is it a tuner gone bad?
Any ideas?
#90
Hey guys,
Any ideas?
Any ideas?
