Weird sound when going over speed bumps
Take care,
Old Oiler
Try this, while driving over the bump step on the ebrake a little. I tried and it doesn't happen, and I took it to Lexus and they told me that it is because of the two emergency brake in the back is causing this and he told me its normal. So he basically didn't do anything about it, and yes it is very annoying
This is an issue my car is currently at the dealer for. I could of swore I saw a TSB for a seat click. Can anyone help me find it? I want to send it to the dealer and see if it applies to my car.
WELL I DIDNT TRY THAT, BUT I DEF TOOK IT TO THE DEALER.. GUESS WHAT, EXACTLY WHAT YOU SAID.. SO I HAVE GOOD AND BAD NEWS.. THE GUY AT THE SHOP TELLS ME, WELL I KNOW ITS ANOYING, ESPECIALLY WHEN SO MANY PEOPLE COME IN BECAUSE OF THAT.. AND YES ITS THE EBRAKE SYSTEM OR WHATEVER.. HE SAID HE IS WORKING ON A WAY TO FIX THIS.. BAD NEWS IS THAT HE CANT ELIMINATE THE NOISE BUT HE CAN REDUCE IT... SO IT WONT SOUND AS MUCH... SUCKS, I KNOW... THE SOUND IS SO ANNOYING, I JUST BLAST THE MUSIC WITH WINDOWS DOWN HOPEFULLY NOBODY WOULD HERE THE "CLICK CLACK" OR THE "TICK TICK" AS I GO OVER SLIGHT SMALL BUMPS IN NYC STREETS..
well my friend, you are brave!.. lmao..
Well I came back from the dealer and the click I had turned out to be my passenger seat back clicking. Sounds different from your clicking noise. Mine was caused when someone sat in the passenger seat and you went around a turn or over a bump. The dealer is replacing my passenger seat.
Website of TSBs.
Website of TSBs.
Website of TSBs.
Website of TSBs.
I had the rear clicking problem when I go over bumps, too. When I went to the dealer, they said they couldn't hear it. Then I went back, and they said they did hear it. I was told it is "normal," and they took me out in a new IS to hear it. They said it was the suspension. However, when I called corporate to *****--I don't see why a brand-new car should make a noise over every damn bump--they said it was the calipers. BS.
I have an IS250 AWD. I had a slight "tic" noise from the right rear when going over bumps at low speed. They just fixed it today, and told me it was an adjustment in the emergency brake. I have just under 1K miles. Anyhow, no more tic! (but it took them about 4 days - they even replaced the strut first, to no avail)
