tires
Old Mar 21, 2007 | 05:25 PM
nehal51086's Avatar
nehal51086
CL Folding 100,000
Default tires
as i read on different posts the more air there is between the wheels and the road the more comftable the ride will be...wit that said what are the "tallest" tires i could get on my IS 250 with the oem 18s and would width make a diffence?....performance isnt that big of a priority for me because its just not the way i drive....however traction and treadwear are....any sugestions on what i should look into for my next set... i have about 14000 on the dunlopes....
Old Mar 21, 2007 | 07:06 PM
rhsmd's Avatar
rhsmd
in a rear wheel drive car, without good grip and traction = performance, it won't be long before you've got lots of air between the tire and the road
Old Mar 21, 2007 | 07:10 PM
Bichon's Avatar
Bichon
The proper way to do what you want is to buy smaller wheels. It's called "-1" or "-2" sizing. That way you'll be able to run a much taller tire without altering the rolling diameter, which would throw off your speedometer, cause clearance issues, etc.
Old Mar 21, 2007 | 08:24 PM
nehal51086's Avatar
nehal51086
CL Folding 100,000
in that case ill stick with the same size....thanks
Old Mar 21, 2007 | 09:24 PM
caudlek's Avatar
caudlek
In the winter i am running :
17" Wheel is SPYN D5 Hyper Silver
front 225/45R17 94 R XL
rear 225/50R17 98 R XL
You would have to change the rim to 17's ...... u might get enough $$$ for your OEM rims to pay for them ..... might.
KC
Rhambler
Feb 4, 2016 06:25 PM
JTremain
Wheels, Tires & Brakes Forum
Sep 17, 2014 12:15 PM
G02
Jan 18, 2008 02:12 PM
CO-LS400
Sep 20, 2006 05:03 PM
EyesOnly
Nov 24, 2005 02:32 AM
