Navigation Hack Alternative - Hybrid Nav DVD
There are 100s of people on this forum with 2006 ISx50s, who have the V5.1 disc and have ZERO problems... Using this method is just like having a 2006 ISx50, no difference...
If you are having problems, then use the newer firmware and lose the override...
Or, do what I did and install an override switch + the newer firmware...
I'm convinced that a sizable fraction of the people with the old software who think they aren't having a problem aren't aware that they are having GPS problems because the dead reckoning function that acts as a 'back up' for the GPS is covering up the problem.
My colleague at work thought he was having zero problems with the nav in his '06 IS. But when we went out to his car in the parking lot, I showed him that the GPS indicator under the map scale was MIA. He didn't realize his car was navigating by gyros and the speed sensor.
My NAV has developed the dropped GPS over the past three months. It wasn't too bad at first but now it won't correct itself for over 100Km! I showed the service manager when I went back about the wrong brake pads issue and he did a recalibration even though the GPS was not locked,...I didn't bother to tell him that it wouldn't fix the problem because I have to go back for the pads,...aggghhhh.
I was going to wait for the survey that you get in the mail... But ya, I will call them up for sure...
you know it could be that they just missed getting the legal authorisation to implement the override before they had to lock down the features all throughout 06 and thus 07, maybe we'll see something different in 08 going forward.
It's a shame that the nav nanny isn't getting some attention in the car mag writeups. I credit the fact that virtually every review I read complained that you couldn't fully disable traction control with Lexus relenting and giving '07 buyers a working Trac off button.
You are 100% right, the mags should start talking about a $2000+ nav option and if it's worth it... We all know the mags HATE electronic nannies, so...
Also, did you ever get your winter tires on?
Hi all,
Hope that this post get's noticed after 2 months of the last reply.
Situation:
1. my car doesn't come with navigation and I bought one from ebay. my car is RX300 2002 and the dvd computer I bought is generation 4.
2. my navigation system is US system. running 04.02 map data version. It's fourth generation system.
3. I bought my country dvd which is also for fourth generation. map version is 2004-2005 (!!!!)
Problem:
when I put my country dvd it tells me that dvd is not correct.
Action I did:
I noticed what you did here and attempted to do the same. I copied my local dvd then overritten the loading.kwa file with the US file. here is the result:
Results:
- DVD is loaded and I get the "I agree" screen.
- Once I agree, I get the message that the system couldn't read the map data and I need to insert the correct disk.
Different things I did:
1. my country dvd is less than 300mb. So, the dvd i burned is not dual layer. it's regular one (is it a must to burn a DL dvd?)
2. I didn't do the fuse thing. I couldn't find any fuse that has the TV-1 name. My car is not loaded with navigation originally (could I do something else?)
3. regarding the buring mode and format, I didn't find the option "etcif". I'm using nero, imgburn and Ultra ISO. how can I do that? (i'm totally ignorant in these matters)
Appreciate any help you could offer and many thanks,
Situation:
Problem:
Action I did:
Results:
I'm going to try to make this combo disc, but I had a thought. I'd like to compare the 5.1 disc w/ override and the 5.1 disc w/o override. I'd be curious to do a hexedit comparison of the two firmware files. If there's little difference between the two files outside of the override, we may be able to pinpoint the same byte (or bytes) in the 6.1 firmware that will allow us to enable the override setting. Has anyone tried this? PM me if you think you can help.
But what I'd like Lexus to do with their future models is to detect if someone is sitting in the passenger seat and if so to enable the NAV while driving. They already must detect passenger weight, since it senses a seat belt that's not latched. Not only is this a logical feature to have, to allow the passenger to change directions while the driver concentrates on the road, it would allow us modders to easily hack it to always allow NAV operation while driving.
Doing a hex edit compare is just about useless. I have the 1600 firmware which includes the GPS update but does not include the HVAC update. The 1600 firmware is 47 kb. The 1650 firmware is 73.4 kb. I browsed the 5.1/1600 with a hex editor, and there isn't much useful information (but you can see a complete list of the voice command error messages in more than one language...). It is also quite clear that this loading.kwi file covers the entire Toyota range. There is a lot of Prius specific information in the file for the hybrid drive system. So, the updates could be for multiple platforms, not just the ISx50 Gen 5 nav system.
I have some other tricks up my sleeve, but I'm a bit preoccupied with moving right now and doubt I'll have anything new on this anytime soon. When I do, I'll post something here.
But yes, you are right, it makes perfect sense to allow the passenger to enter destinations...
