2007 IS350 XM installation
Old Nov 17, 2006 | 02:58 PM
ecr527's Avatar
ecr527
I installed XM on my 2006 by myself. It was pretty easy. The most difficult part, like everyone said was yanking out all of the trunk liners. If you have an 07 with the shark fin antenna, it should be even easier since you don't have to remove the trunk lid liner to run the antenna wires.
Old Nov 27, 2006 | 06:19 PM
ICMAX's Avatar
ICMAX
I installed the XM myself, and the only issue I have is the reception. I tried placing the antenna on the third brake light and sticking it to the rear glass for better reception. Unfortunately, this has not worked. My next move, will be to place it on the outside for a better reception. I will try to run the wire from the trunk and around the rear glass to the top center of the roof where they usually locate the shark fin antenna. I hope this will work.
Old Dec 14, 2006 | 01:53 PM
tay100's Avatar
tay100
Originally Posted by kaslead
Look at the pic in this post, you can see where the antenna is located.
https://www.clublexus.com/forums/sho...&postcount=331
Hey kaslead can you tell me where you got the connectors you used for your fix? Instead of cutting the plug from the shark fin how about making an adapter cable with the appropriate plugs on the ends? I want to try to make one that will fit my Terk XMD1000 (yes, XM not Sirius!). That means on end will plug into the existing shark fin adapter and the other into the Terk Unit which plugs inot the VaisTech adapter. I want to try to install this in the trunk but cannot get a good answer from VaisTech as to whether or not there is anything back there their unit will plug into. In fact the VaisTech people just gave me a short, smartass answer to that question.
Thanks for your thoughts on this.
Old Dec 14, 2006 | 01:57 PM
07Txlex's Avatar
07Txlex
So people with no ML only have to do install in the trunk? For 100% sure?
Old Dec 14, 2006 | 03:00 PM
tmf3lehigh's Avatar
tmf3lehigh
Yes, everything connects in the trunk.
Old Dec 14, 2006 | 03:20 PM
07Txlex's Avatar
07Txlex
Is this with the XM and Sirus or just XM?
Old Dec 14, 2006 | 03:22 PM
tmf3lehigh's Avatar
tmf3lehigh
I believe it is both.
Old Dec 14, 2006 | 03:24 PM
07Txlex's Avatar
07Txlex
Don't see why it wouldn't apply to both units being they are extremely similar
Old Dec 14, 2006 | 04:55 PM
ES3's Avatar
ES3
Good stuff, please post pics of the sat channel displays as they appear on the nav!
Old Jan 28, 2007 | 08:41 PM
nighthawk's Avatar
nighthawk
Can someone explain what is meant by "re-initializing the one touch up/down windows on all doors" ? Do I just need to go around and press on the windows for each door? Or is there something else I need to do?
Old Jan 29, 2007 | 10:08 PM
nighthawk's Avatar
nighthawk
Can anyone help here?
jtrain73
14
May 14, 2016 09:31 PM
jamessinh
Jan 19, 2012 02:57 PM
Jim_bo
Dec 26, 2006 09:04 AM
looknow12
Dec 8, 2006 05:40 AM
clambros
Jun 4, 2006 03:39 PM
