Question about lowering?
Old Aug 31, 2006 | 05:06 PM
Xelvic's Avatar
Xelvic
Default Question about lowering?
I was thinking about putting the eibach springs in my car. Does this change the toe at all? I don't want tire wear issues. Thanks guys.
Old Aug 31, 2006 | 05:18 PM
Flipsonic's Avatar
Flipsonic
If you get an alignment after the springs are installed, toe can be put back to center. However, camber cannot go back to stock specs. They can get it close though. At least that's what I was told. I'll have mine on next week. As for tire wear issues, if the alignment is done properly, it shouldn't be an issue. Then again, all the peeps with the Eibachs haven't had them on for a while to experience tire wear.
Old Aug 31, 2006 | 06:49 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Camber is not adjustable at all on any RWD ISx50. Anyone telling you it is adjustable is lying.
Old Aug 31, 2006 | 07:20 PM
kilo6_one's Avatar
kilo6_one
i just got my toe adjusted.......it was out bad.
Not to sound uneducated, but this is my first RWD car, what exactly will they do if i get it "aligned"?
will they do more then just a toe adjustment, since Lobux is right they cant do anything to the rear camber.
Old Aug 31, 2006 | 07:24 PM
acl15's Avatar
acl15
is it necessary to get tire allignment after installing springs? do you do it right after or a week later after the springs settle?
Old Aug 31, 2006 | 07:42 PM
4TehNguyen's Avatar
4TehNguyen
wait about 2 weeks after the install. Anytime you mess with the suspension geometry you have to get an alignment
Old Sep 1, 2006 | 01:42 AM
Xelvic's Avatar
Xelvic
Thanks guys, you told me everything I wanted to know.
LeeJonah
Mar 26, 2017 07:11 PM
ccroney
Suspension and Brakes
Mar 7, 2016 05:05 AM
monkeybutt
Apr 17, 2011 12:38 PM
istundra
23
May 24, 2008 11:26 PM
92 SC400
Oct 29, 2007 12:30 PM
