After Market Spoiler
Right, you'll get permanent holes. That means if you ever decide to remove the spoiler, you'll have holes in your trunklid. Plus you have the possibility of water entry into the holes, etc. Not a good approach in my view.
Adding the spoiler with double-sided 3M Molding Tape is quite easy, and will give you the option of removing the spoiler without holes.
BTW, my wife's Crystal White IS250 is just like yours. She doesn't have a spoiler, but is considering one. If I were to add it to her car, I'd use the tape route I described above, and not drill holes.
I drilled and bolted mine because I will have peace of mind it will stay on. If you have peace of mind with the 3M tape, I say go ahead and tape it. Each person is different. If you decide to changeout the spoiler later, I hear people have a hard time removing the 3M tape. They had to use a screwdriver or something to scrape it off. I wouldn't want to do that to my trunk door. I will never change my spoiler, it's permanent. As for the holes, I used a rust inhibitor. Also, I looked at the inside of the trunk, there's no way water will get in. Not saying 3M tape is not a good route. Everyone just has a different way of thinking.
Interesting!!! Never thought of the possibility of water getting in the holes and resulting in rust. Now that is something I have to consider prior to getting a spoiler. Once installed, I have no intentions of ever removing it. But I have to weight the pro and con here. I really want and like the spoiler. I feel the back is somewhat naked without one. How strong is the double sided tape? Will it withstand weekly washing? Will it last indefinitely....or at least 6 years? As long as it doesn't just fly off on the freeway, perhaps something to consider.
How does Lexus install it? Holes or tape? If they drill, would they put rust inhibitor?
Lexus would drill holes and use the rust inhibitor. I went with the Lexus installation instructions. I used the rust inhibitor around the holes. As you are drilling, very small unpainted parts around the holes will become exposed. You'd want to protect the holes at both sides of the trunk door with rust inhibitor. IMO $188 + self install + aligned perfect = can't beat that.
For water to get into the holes, that must mean the double sided tape isn't that good, right? If you drill the holes and torque down the bolt, it will put more pressure on the tape, creating a tighter seal.
Just using tape will work for this application. The spoiler is very low profile and does not create that much drag. I bolted my spoiler down and have no concern of water leaking into my trunk.
where i live in the summer when its 117 degrees the 3m heavyduty separated the 3m from the car (different car) i would go with drilling the holes, if your worried about water put a thin bead of silicone on the hole to hopefully fill any tiny areas where water could get in.
would having the dealer install it provide any security warranty wise for those who are worried? it may be worth the cost...... IDK, anyway id like to do a spoiler and i would do the drilling the hole route.
usually the bolts that hold down the spoiler will get some rust inhibitor + orings goes around it. It will get wedged b/t the trink lid and spoiler and screw head and inside the trunk to seal. Thats how it was when I got the OEM spoiler on my prelude, 6 years no rust
As for leaks, I've only had mine on for two weeks and it hasn't rained yet (typical CA weather). I've washed it one time, spraying water directly at the spoiler, checked for leaks, nothing.
ouch $452??? the labor cost just as much as the spoiler itself! i did mine in less than an hour... it's really not that hard. im sure you can do it yourself provided you have a drill.
i'd help you install it but i'd feel horrible if something messed up. if it was my own car the only person i could get mad at is myself for screwing up.
Cali, if you're worried about installation, bite the bullet and have the dealer install it. Yes, its expensive, but if something goes wrong, you'll be able to complain and have it fixed under warranty.
