Hid beam pattern question
Many cars that are equipped with an HID (OEM) have a certain beam pattern design. Just because you have projecter doesn't mean it's made for HID. They could be designed for halogen bulbs. So .. my question.. if i get a non xenon equipped IS and i install aftermarket HID .. will this give you the same result as OEM equipped HID.
I'm asking do we still get the clean cut beam pattern.. Thanks |
Judging by what all the people who converted their non-HID cars to HID...I would say it's a clean cut beam pattern. Do a search and find out.
you still do get a clean cut beam pattern
the cut off beam pattern may not be as sharp if the hid kit is too blue. i.e. a 4300K beam pattern will be sharper than a 10000K kit. The higher the light wavelength, the more it will scatter and have more 'glare' to oncoming traffic..not cool!
these pics may answer your question: https://www.clublexus.com/forums/sho...=212190&page=3 hth |
Originally Posted by omgitsroy
(Post 2095243)
I'm asking do we still get the clean cut beam pattern.. Thanks If you get the 4300 it's a very clean pattern, just make sure you get a good kit,alot of my friends got other kits and did not drill the dust cap and got condensation in the lamps. I went with xenondepot.com, very well made kit. It took a while to come, but it was worth it. |
what exactly do you mean by KIT.. i thought they were bulb and ballast... that's it... what does the kit have?
i think when they say kit.. they mean it includes the wire harness to wire n connect everything together. plus the rubber grommets for the bulb wires.
how would you not buy a kit.. kinda confusin no?
kinda like saying.. buy a car with doors |
(Post 2096697)
