what are some recalls?
Old 05-28-06, 08:27 PM
doctorttt
doctorttt's Avatar
Default what are some recalls?
Have been reading some posts in regards to seatbelt and pedal recalls. What are the problems??? Are there other recalls besides those? Are recalls at no cost? Wtf? It's Lexus; can't belive they mess things like up like that. Thanks.
Old 05-28-06, 09:30 PM
Bichon
Super Moderator
Bichon's Avatar
The gas pedal recall, which happened very early in the model year, affected only the all wheel drive model. The recall involved a modification of the pedal assembly to prevent the gas pedal from getting caught on the carpet.
The seatbelt recall, which affected a much greater number of cars, replaced both front seatbelt due to a possible failure in the retractor mechanism.
Recalls (from any manufacturer, not just Lexus) are done at no cost to the consumer.
Old 05-28-06, 10:13 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
It's only been a couple of recalls, and only the seatbelt recall affected the global 2nd Gen IS community. This is very troubling for Lexus, as their quality standard is slipping. You're still far off better than other autos out there; the Chrysler 300 had recalls for its brakes and tranny, Jeep Wrangler had recalls for its clutch assembly and tranny; and even Ford had to recall over 3.8 million trucks and SUVs due to cruise control problems.
And this is actually a good thing; Lexus caught the problems early before it affected anyone, including yourself. Some automakers will not ask for a recall if the amount of lawsuits from a few accidents are cheaper than doing a recall. Thank God Lexus doesn't do that.
Old 05-29-06, 01:13 AM
RCPiercy
RCPiercy's Avatar
Thanks Tyler Durden.
Old 05-29-06, 07:47 AM
kensteele
kensteele's Avatar
I think the corvette has just been recalled for the roof might coming undone while driving.
You know, it might just be a spin on things, but a safety recall does not necessarily mean that something is broken. IIRC, Lexus said the seat belt has the potential to get caught up and therefore the driver might decide to not use it.
Since all recalls must be safety related, Lexus decided to not take a chance and went thru with the recall instead of some sort of fix or TSB. Apparently there is nothing wrong with the seatbelt, it works when you wear it, it wasn't subject to failure, etc. From what I read, if is got locked up for whatever reason (like a lot of seatbelt often do), it might be so difficult to unlock it that you may have to drive without using the seatbelt. Mine never did that. But Lexus played it safe and I doubt they performed the calculation. Finance, accounting, and legal department don't run all companies.
Old 05-29-06, 08:27 AM
mwaull
mwaull's Avatar
So when my IS350 comes to the dealership about a month from now, are they going to due all the necessary recalls before i get there? Without me asking . . .
Old 05-29-06, 08:30 AM
tigmd99
tigmd99's Avatar
You should ask them to look up any recalls for your VIN number. I would also take a copy of this thread just in case their computer misses something.
Old 05-29-06, 08:36 AM
kensteele
kensteele's Avatar
for the 350, there is only one recall, you should ask them to lookup the vin to see if it is part of the recall and if it is, ask them to order the part and fix it prior. call them and ask them to do this since you know 100% what needs to be done.
Old 05-29-06, 08:47 AM
LexFather
Guest
Posts: n/a
SEARCH under recall in 2nd gen IS forum.
Old 05-29-06, 03:27 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Someone actually got that...
j8123
IS F (2008-2014)
194
06-26-11 12:25 PM
Richard95
ES - 5th Gen (2007-2012)
84
07-06-10 09:29 AM
xfirechief
01-22-10 08:51 AM
Bon
11-26-09 11:08 AM
KPC
IS - 1st Gen (2001-2005)
06-07-07 04:13 PM
Quick Reply: what are some recalls?
