Sport Pedal Install
Old 05-27-06, 12:42 PM
  #46
uschardcor
uschardcor's Avatar
go for it bud. after my microfibers dry i'm going to wash and wax her, then try the accelerator install, without a vicegrip. should be interesting...
Old 05-27-06, 10:09 PM
  #47
AndyL
AndyL's Avatar
Without a vise grip? If you succeed, please do let me know how. Be careful not to bend the accelerator.
I would love to know about it.
Old 05-28-06, 11:42 AM
  #48
RCFormante
Supercharged!
RCFormante's Avatar
I did it without a vise grip...just find a blunt nail, position the pedal on the ground so that it wont move, and hammer the pin until it comes out...really easy.
Old 05-28-06, 04:14 PM
  #49
AndyL
AndyL's Avatar
To those who got the dead pedal installed successfully,
I just tried with a long stem screwdriver in order to pry the original dead pedal out but it seems that the plastic fastener is too tight to be removed when prying it. Is there any tricks?
Also to those who used brute force, did you actually get the original dead pedal damaged a bit in order to make it work?
Any response/help is greatly appreciated.
Thanks
Old 05-28-06, 08:59 PM
  #50
AndyL
AndyL's Avatar
Just figured how to take off the original dead pedal.
I ended up using the brute force without any screwdrivers. It was much easier than I thought.
It is much easier to use the brute force on a pedal which is actually on the car rather than trying it on a pedal detached.
Took some pictures.
The car without the pedal. I can testify that the insulation under the carpet is very very thick!
Due to the poor lighting and the angle, you won't see the white clips inside the holes..
Old 05-28-06, 09:02 PM
  #51
AndyL
AndyL's Avatar
It is interesting to know the size of the plastic dead pedal is slightly larger than the spors dead pedal.
Old 05-29-06, 04:43 PM
  #52
IS350ISFUN
IS350ISFUN's Avatar
Default Bay Area
Has anyone in the bay area sucessfully completed this MOD ...... lets meet up ..... I need help!!!! forget about the six pack....I'll bring two 12 packs
Old 05-29-06, 06:54 PM
  #53
AndyL
AndyL's Avatar
Default Look what I have got...
I ended up using Darrel's original method to take off the pedal as I was concerned about messing up the springs inside the accelerator pedal assembly. I bought a very small rachet set and it really worked.
I partially took off the plastic panel under the knee airbag to squeege more room. Then I tried to see how tight the washer (Note: not a screw) on the left lower corner on the L logo plate was. Then with my fingers of both hands feeling where the top right screw was, I was able to place the small rachet on the screw to release it. As soon as I got the rachet on that right top washer (see the pictures), the rest was pretty straight forward. You just have to be very careful not to drop the washer somewhere behind the carpet material.
Another thing is you have to take off the connector and the plug before removing the entire accelerator assembly out. You don't need any tool to detach the connnector. Just press the tab and separate them.
I still have to get the pin out from the pedal..Looks like I can see my sports pedals completed soon.
Thanks for all the members who helped me in this DIY
Old 05-29-06, 06:55 PM
  #54
AndyL
AndyL's Avatar
The accelerator assembly
Old 05-29-06, 06:56 PM
  #55
AndyL
AndyL's Avatar
Another shot on the accelerator pedal
Old 05-29-06, 06:57 PM
  #56
AndyL
AndyL's Avatar
The front view on the accelerator assembly
Old 05-29-06, 06:58 PM
  #57
AndyL
AndyL's Avatar
The tiny rachet set that I use. Use 10mm
Old 05-29-06, 06:59 PM
  #58
AndyL
AndyL's Avatar
My work area with MF towels
Old 06-14-06, 09:21 AM
  #59
Dj Rando
Dj Rando's Avatar
BUMP
Old 06-14-06, 09:36 AM
  #60
pocky
mooncake master
pocky's Avatar
Well here is a pic of my Sport Pedals installed. It's now complete with the dead pedal, just didn't have in this pic.
I'll tell ya, it's a B&*@# to install the gas pedal.
Quick Reply: Sport Pedal Install
