Oh no- check engine light and check VSC
#106
They tell you that because it is the most common cause of a CEL. It may still come back, and personally, I wouldn't take that route. I'd ask to see the code so I can know if it is an evap emissions fault or something else. They just had you do that because it's simple, quick, and common.
Connecting a scan tool takes all of about a minute total to read a set code, and even a cheap scan tool will be able to tell you if it's the evap system.
#107
After getting my car back from service, I'm happy that the CEL/check VSC lights are out, but it kinda makes me wonder.
So far we've heard reasons like, faulty O2 sensors, gas caps, etc, which may all be valid reasons, my I'm just wondering how any of this is related to a problem related to the VSC system?? I could see the CEL coming on for the O2 sensor and even the gas cap, but the VSC?? It doesn't compute. Next thing you know they're gonna tell us that the ABS isn't working because I'm low on washer fluid.
Maybe it's just me.
Maybe it's just me.
Does anyone that is haveing these lights come on also have an aftermarket intake?
#108
Super Moderator
#109
Super Moderator
I have the same 3 lights comming on as everyone else. I brought it to one of the Techs i know at my Lexus who is a friend of a frend. He said the Check engine light is connected to the VSC, so when ever the check engine light comes on it shuts the VSC off and the light will come on. He did not know what the problem was but said it was probably becuase of my Fujita intake. He said the engine is probably getting too much air and the computer doesnt recognise it or something like that. He reset my computer and the lights went off. He told me to take it back if they come back on. Well, a half hour later after going into a store i turn my car on and there you go, all 3 lights on again. I am going to try and bring it back tomorrow and make him check the gas cap and O2 sensor. The light has been going on and off for a few weeks now.
#110
#111
Tech Info Resource
No, P0200 is a generic code for an injector fault. P0201 through P0206 are specific to an individual injector. All that code tells you is there was a fault, it persisted for a number of cycles, but it wasn't enought to distinguish which injector had an issue. It's not a hard break. It may or may not lead to more codes. The best thing to do is document it happened in your service records and see if it returns.
#113
Super Moderator
#114
Super Moderator
#116
Super Moderator
It goes by warm up cycles. It takes three warm up cycles without the problem to turn off the check engine light. It takes a lot more -- something like 40 warm up cycles without the problem before the code is erased.
#117
Tech Info Resource
Toyota never erases the codes automatically. They have to be reset manually, especially engine codes. Either you pull the fuse/disconnect battery (erases some but not all codes) or you reset with a scantool (resets all codes and can reset learned behaviours.)
#118
i just got the check vsc/engine light last night. i called the dealer to schedule an appt, first available is tomorrow. i am driving my gf's 07 camry now. i'll do the gas cap reseat thingy and maybe even unplug the battery and see what happens.
#119
My VSC light came on 2 days ago as well, my appointment with the dealership is thursday... wish me luck. ><
*edit* - not just my vsc light but the engine and traction light as well.
