Ipod connection
Old Feb 26, 2006 | 09:53 AM
Duke02's Avatar
Duke02
Has anyone had a problem with the volume level on the aux input? I have my ipod hooked up with a basic mini-jack patch cable from best buy but I have to turn the volume all the way up on my ipod to even really be able to hear it and even then there's a lot of background noise. any suggestions? Thanks
Old Feb 26, 2006 | 10:42 AM
DanIS350's Avatar
DanIS350
I spent a while looking for a good cable and eventually found this:
http://www.soundprofessionals.com/cg.../item/SP-HEC-4
It's only 2 feet long, which is actually plenty of length to be able to hold up the iPod, but not long enough to create a coiled mess in my armrest. There are also 90 degree connectors, which I like.
As others have said, the system is only as good as the weakest link, and for most of us out there, that's going to be the mp3 player/compressed songs - even at 192 kbps.
Old Feb 26, 2006 | 11:10 AM
kensteele's Avatar
kensteele
Within iTunes, I always adjust the setting for low volume songs all the way to high, don't know if that helps.
Old Feb 26, 2006 | 03:35 PM
Bichon's Avatar
Bichon
Bad choice. The Sik connector mentioned earler in the thread is MUCH better.
Using your cable the signal is actually running through two amplifiers, the headphone amplifier and the one in the car. With the Sik cable (or any other one that uses the dock connector), you are bypassing the headphone amp and connecting directly to the line level output.
Old Mar 6, 2006 | 11:50 AM
Turkoman's Avatar
Turkoman
Default SiK Connector - How do you power it?
I am new to the forum. Just ordered a 250 AWD.
I am very intrigued by the SiK device and I was wondering if anyone knows of a firewire connector to the car power outlet to keep the iPod charged. This seems like a much better solution than the headphone jack.
Old Mar 6, 2006 | 12:23 PM
deuce2's Avatar
deuce2
get a ground loop isolator..it's a noise filter that will get rid of the background noise.
jjackson
Jul 18, 2021 11:02 AM
dziarmag
Apr 14, 2011 07:37 AM
crazydrago
Sep 2, 2006 10:30 AM
Cleric
Jul 28, 2006 10:32 PM
FastGirl
Jun 11, 2006 01:43 PM
