What is the proper clutch install direction
Old Nov 20, 2025 | 08:26 PM
svm23's Avatar
svm23
2nd gear
Default What is the proper clutch install direction
Doing a clutch change, not 100% sure which way clutch disk is supposed to be installed, asking for some insight.
Does the buldging side face away or towards the flywheel?
Old Nov 21, 2025 | 05:52 AM
Protholl's Avatar
Protholl
Did you take pictures when disassembling it or are you asking before disassembly?
Old Nov 21, 2025 | 05:55 AM
dmanb2b's Avatar
dmanb2b
Step away and have someone who knows what they are doing help you out in person.
Old Nov 21, 2025 | 11:14 AM
svm23's Avatar
svm23
2nd gear
I unfortunately did not get to as when i pulled off the clutch cover the clutch disk popped out onto the ground, so I am not 100% certain on which way the clutch is supposed to go.
Old Nov 21, 2025 | 11:28 AM
If it's like every other manual car I've worked on the shorter side (less protrusion) goes towards the flywheel.
bron_karr
May 15, 2024 08:08 PM
dejacky
Jun 15, 2008 09:23 AM
Camshaft
Apr 10, 2002 07:04 AM
