2006-2008 Memory Seat System Components
Old Apr 17, 2025 | 03:31 AM
Inactive's Avatar
Inactive
Default 2006-2008 Memory Seat System Components
I’m looking to add the electric tilt and telescopic steering column at the very least. From what I can gather I just need a different turn signal stalk along with the steering column adjustment switch, and the ECU’s attached to the steering column. For the memory I believe I need a different door wiring harness, the memory switch, and the mirror ECU.
I’m not very sure about any of the connections in the middle of the system though. I don’t know if getting the right door wiring harness is enough as I don’t know if those wires will end up going where they should, like to the steering column ECU.
Can anyone provide any sort of insight? Prices have went down a ton since these parts are now used and old, so I have the perfect opportunity to try and make this retrofit work. Especially since I don’t care about getting memory seats or mirrors, I just want the electronically adjusted steering column.
jlficken
GX - 2nd Gen (2010-2023)
31
Jan 22, 2026 03:30 AM
fedcrom
Nov 10, 2024 05:26 PM
Inactive
May 29, 2024 12:59 PM
Tantrix
Aug 19, 2016 08:18 PM
10lexISR6
Dec 1, 2014 10:32 AM
