replaced transmission same issue
Old Mar 31, 2025 | 02:47 AM
Drako's Avatar
Drako
2nd gear
Default replaced transmission same issue
I have a 2006 Lexus IS350 that has always run fine until a couple of months ago when it started experiencing shifting issues. Delayed shifts and jerky gear changes. When launching at full throttle from a stop, the car initially pushes forward like it wants to go but then slows down and refuses to change gears. it just revs to around 4-5k rpm when full throttle and stays there. when driving conservatively that car shifts ok. Since no check engine light or error codes appeared, I took it to a mechanic. The initial advice was to service the transmission and check the catalytic converters, which I did but the problem persisted. At this point, I decided to replace the entire transmission with a used one from a trusted parts supplier. During the replacement, the mechanic also noticed that one of the headers was missing a catalytic converter. not sure if my pops and bangs tune caused that However, after installing the replacement transmission, the issue still remains exactly the same. I'm at a loss for what to check next. Has anyone experienced something similar, or does anyone have suggestions on what else could be causing this? you guys are me last hope
Old Apr 3, 2025 | 08:22 AM
SB4600250's Avatar
SB4600250
7th Gear
Hello, how many miles does your IS have?
Another question is why your car has one of the headers with a cat and the other is catless?
jmend350
Build Threads
Feb 18, 2025 12:20 PM
jhomer42
Jan 17, 2024 07:00 PM
Klao
RX - 1st Gen (1999-2003)
Oct 29, 2023 08:15 AM
ready305
NX - 1st Gen (2015-2021)
Jul 13, 2023 07:59 PM
actualtoma
May 19, 2023 09:05 AM
