Wheel hub Assembly
Old Jan 16, 2025 | 03:29 PM
DarkLexus's Avatar
DarkLexus
2nd gear
Default Wheel hub Assembly
Is the left and right the same for the assembly with bearing? I've got to order one for the left driver's side and I just want to be sure.
Old Jan 25, 2025 | 03:56 PM
Yodog's Avatar
Yodog
only for the front wheel bearings
Old Jan 25, 2025 | 10:05 PM
firestart9's Avatar
firestart9
What about the years? Does 2006 match 2011 or does the fit change?
Old Jan 26, 2025 | 04:15 AM
Yodog's Avatar
Yodog
they all fit. The only differences are if your car is rear wheel drive or all wheel drive.
Old Aug 27, 2025 | 01:47 AM
tobychap's Avatar
tobychap
1st Gear
Wheel hub bearings assemblies generally come as complete units with the bearings already pressed in, but whether the left and right are the same depends on your vehicle’s design. On many cars and trucks the hub with bearing is identical for both sides and can be swapped, but some models have side-specific hubs due to ABS sensor placement, lug orientation, or mounting differences. To be safe, double-check your vehicle’s part number before ordering to ensure you get the correct hub and Deep Groove Ball bearing assembly for the driver’s side.
Old Sep 4, 2025 | 07:11 AM
Cienfueg69's Avatar
Cienfueg69
Front left and right has different part numbers
https://parts.lexus.com/a/Lexus_2008...3-9C33288A110E
Gavroche
GX - 1st Gen (2003-2009)
Nov 18, 2019 12:21 PM
Gville350
May 28, 2019 11:14 AM
little2576
Sep 5, 2015 12:23 PM
oohpapi44
Oct 19, 2006 01:59 AM
