Carbon cleaning
Old Dec 10, 2024 | 05:02 PM
BobtheBuilder's Avatar
BobtheBuilder
3rd Gear
Default Carbon cleaning
Recently I've used the cnc carbon cleaning kit because I've had rpm fluctuations with no code. I sprayed the cleaner through the brake booster vacuum line and everything was okay except, I noticed that a clear fluid which I think may be the cnc fluid is leaking from somewhere above the transmission. I haven't done the highway drive yet and I'm waiting on the heat soaking process but I noticed my rpms were still fluctuating. Any ideas? My educated guess is my rpm jumps arent from carbon but from a vacuum leak or a bad intake manifold and that's where the fluid is leaking from.
Old Dec 11, 2024 | 04:12 PM
MikeFig82's Avatar
MikeFig82
The fluid you're seeing is probably the AC drain dripping on the floor.
Check the purge valve and, lines for cracks.
https://www.clublexus.com/forums/is-...and-p0441.html
808LSX
Performance
Apr 25, 2023 07:57 AM
CowBoE
Jan 17, 2022 01:27 AM
DixieLex
Oct 11, 2018 10:01 AM
jfungy
Apr 3, 2017 06:56 AM
primecut
Automotive Care & Detailing
May 9, 2010 08:15 AM
