Cooling
Old Oct 26, 2024 | 11:47 AM
ketang's Avatar
ketang
1st Gear
Default Cooling
Hello. Lately I have had a problem with my car overheating which broke two radiators.
I replaced the thermostat, water pump and cap... the problem is back .
The temperature sensor (OBD) shows 95-96 degrees Celsius when the fans turn on in high speed mode. Is this the right temperature? Shouldn't they turn on earlier in lower speed mode (at what temperature)?
The lower fan speed mode works when I turn on the A/C.
Is the temperature displayed through the OBD port the same as the indicator on the dashboard?
Is it the same sensor?
Thank you.
VIPnsanity
May 15, 2026 04:11 AM
JamesAbbe
NX - 2nd Gen (2022-current)
14
Jan 14, 2022 02:58 PM
Bocatrip
Sep 19, 2018 01:11 PM
lexusKAS
Jun 9, 2018 09:25 AM
mrrhr4
Sep 3, 2013 11:19 AM
