Battery hooked on backwards 2011 Lexus is250.
Old Aug 6, 2024 | 07:32 AM
Dylan1995's Avatar
Dylan1995
1st Gear
Default Battery hooked on backwards 2011 Lexus is250.
2011 Lexus is250. Was out of town and let my mom use my car. She got a friend to change the battery and he connected battery on backwards. Car wouldn’t start. Blew the fusible link. I swapped the fusible link yesterday, car started right up. Dash is lit up like a Christmas tree now. Power steering doesn’t work, windows won’t go down, check engine light on,no abs, radio won’t turn on, display won’t turn on, etc.
Old Aug 6, 2024 | 11:28 AM
Protholl's Avatar
Protholl
You've got a long way to go checking fuses, validating wiring and scanning modules. Good luck.
Old Aug 6, 2024 | 11:29 AM
2013FSport's Avatar
2013FSport
Although I wouldn't recommend driving it without power assist, you need to read the codes from the various on board computers.
On a 1 to 10 scale, how certain is the workmanship in this repair? Can you share which links blew? 9 out 10 times the 80A power steering link is toast. Usually there are not this many issues? What is the battery voltage after starting? If low and under 12.0, the incident could have taken the alternator out. Start with system health check and do a search, you are not the first unfortunately.
PS look here, phone app $40 you can read codes.
https://www.clublexus.com/forums/is-...-pid-pack.html
kmax1980
RX - 3rd Gen (2010-2015)
19
Dec 2, 2025 09:25 AM
2011LexusIS250
Aug 5, 2024 09:03 AM
zblitz1
CT 200h Model (2011-2017)
May 22, 2024 01:41 PM
mdavid13
Jan 5, 2018 10:29 AM
