Weird whirrling sound
Old Jan 30, 2024 | 07:57 AM
Lexus0100's Avatar
Lexus0100
10th Gear
Default Weird whirrling sound
Hey,
I noticed this whirling sound for a little time now. I wondered if anyone came across this and could explain to me whether this is the idler pulley or water pump or the alternator pulley or the serpentine belt or the sub assy belt that comes in one piece with the adapter? When I purchased the car this sound was not present.
https://voca.ro/1gXf1dNnLtqr. - this is the recording for the sound.
Old Jan 30, 2024 | 12:39 PM
Lexus0100's Avatar
Lexus0100
10th Gear
anyone able to help?
Old Jan 30, 2024 | 12:52 PM
2013FSport's Avatar
2013FSport
Audio doesn't depict anything outstanding. This is a 250? It sounded like a 350 after startup where it switches from port injection to direct injection during warm up...
Grab some Windex or spray glass cleaner, place the nozzle on stream and spray the belt. If the sound goes away, maybe just a little belt slip. Use a stethoscope or long dowel to suspect areas. Place the other in your ear to pinpoint source .
Old Jan 30, 2024 | 03:01 PM
Lexus0100's Avatar
Lexus0100
10th Gear
yeah it is a 250 ... if you focus a little there is whirling sound not the ticking sound ... often times they say its the water pump so I'm puzzled.
Old Jan 30, 2024 | 03:51 PM
2013FSport's Avatar
2013FSport
Currently an aged belt on the Tundra makes extra noise when the humidity hits >95% at startup. That little bit of extra moisture allows the belt to slip and can be pretty loud.
Suggest trying a spray cleaner like Windex and listen for sound change. Often times they go silent for 30sec. Which isolates noise to belt slip vs failed pumps/bearings.
dchan865
GX - 1st Gen (2003-2009)
Dec 31, 2017 10:30 AM
LateNyta
Aug 2, 2013 02:02 PM
herrajdm
Jul 21, 2011 07:07 AM
Pescao
RX - 1st Gen (1999-2003)
Mar 2, 2009 07:30 PM
underpsi
May 18, 2007 04:51 PM
