Help with A/C recharge procedure
Old Sep 16, 2023 | 11:48 PM
Idkyet2is's Avatar
Idkyet2is
Default Help with A/C recharge procedure
I'm going to be putting in my new used engine soon and my entire ac system was depressurized and bled out.
I'm not too savvy on the AC system, all I (think I) know is I need to put some PAG46 into the compressor, fill with R134a, and some sort of A/C recharge kit.
Does anyone know the proper procedure and measurements to recharge it? Any tips are greatly appreciated 👍
Old Sep 17, 2023 | 09:05 AM
Protholl's Avatar
Protholl
This is something you take to a mechanic. You need to draw the system down to a vacuum and then monitor it for at least 10 minutes to assure there are no leaks. There are machines made for this and its not something that a driveway mechanic is qualified for. There are regulations for the handling of refrigerant because of the environment. Also make sure you use new, purpose built o-rings for the pipe seals and you should replace the high and low side schrader valves.
Old Sep 17, 2023 | 02:51 PM
Idkyet2is's Avatar
Idkyet2is
Damn ur right I'm not qualified just being a low experience driveway mechanic 😞. Let me take the new engine out, put the old one back in, sell the cherry picker, tow it to a mechanic and just pay em like 3k to swap it for me.
Jokes aside, I appreciate your response but I believe this is something very doable for a driveway mechanic as long as you do the proper research and are careful like with any other job. I will definitely replace the seals, but are the schrader valves really necessary?
I plan on flushing the system, I already have a vacuum pump so I just gotta buy an ac manifold gauge set, emptying the compressor oil, replacing condenser with dryer and filling with PAG46 and r134a with a bit of UV dye.
Any other tips are greatly appreciated 👍
Old Sep 17, 2023 | 03:38 PM
Protholl's Avatar
Protholl
OK so you didn't reveal you had the tools and knowledge (things like adding the same amount of oil in a new compressor as the old) in your post so I apologize. Beyond an actual mechanical failure one of the most likely leaks comes from the schrader valves so most mechanics just replace them as a maintenance item. They are just another rubber ring on a spring and they are cheap. I'm guessing you also have a UV flashlight and glasses?
The amount of refrigerant should be on a sticker in the engine compartment. As far as measuring you can use a kitchen/snail-mail scale to measure the weight of the refrigerant can during the recharge procedure. Just make sure the hose that connects to the can is not moving around adding/removing weight which will affect the scale's accuracy. I am assuming you're using small cans of course.
Good luck with it. I've just seen too many people watch a couple of youtube videos, buy something from Amazon and a week or so after they have "fixed" it suddenly the AC no longer cools (leaks galore) and all of that refrigerant has been blasted into the stratosphere.
V/R
Old Sep 17, 2023 | 07:15 PM
Idkyet2is's Avatar
Idkyet2is
V/R
no need to apologize, I was just joking haha. Thanks for taking to time to share your knowledge, I'll take all your tips into consideration and I'll look into replacing the schrader valve 👍 Hopefully I'm competent enough to recharge it properly haha
texsexlex
Jun 7, 2017 03:09 AM
ArkLaTexSC
Mar 16, 2014 05:03 PM
jami1
15
Jun 19, 2013 04:28 PM
Levistey0
May 6, 2008 11:18 PM
POS
May 12, 2005 12:21 PM
