Live data O2 readings and code P0420
Old Sep 1, 2023 | 01:17 PM
1stock2is's Avatar
1stock2is
2nd gear
Question Live data O2 readings and code P0420
I was having some trouble with a code P0420 which is for the bank 2 catalytic converter. I did some more digging and tried using the live data to read the O2 sensor readings and both my upstream sensors (O2S B1 S1 and O2S B2 S1) were reading a little over 3 Volts. However my down stream sensors were reading correctly between 0.1V-0.9V. I was wondering if there is any other live data I should take a look at to help me figure out what the problem really is as my OBD2 scanner does give me a lot of info. If anybody knows what I should be checking and the correct readings it would be very appreciated.
das1960
Mar 27, 2023 07:24 PM
cajunboy
GX - 1st Gen (2003-2009)
Feb 15, 2021 09:32 PM
bd3471
Aug 12, 2019 11:29 AM
vighnesh
Hybrid Technology
May 7, 2019 02:03 PM
pslack
Maintenance
Feb 1, 2013 02:42 PM
