IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
1G-FE Alternator Replacement
Old Feb 14, 2022 | 07:12 AM
ryanboost's Avatar
ryanboost
Default 1G-FE Alternator Replacement
Good day, can you advise which higher amp alternator can be used to replace the old 90A 3 Phase alternator in the Beams 1G-FE Lexus Altezza Engine? Can the 1JZ or 2JZ Alternators work or bolt up?
Old Feb 14, 2022 | 10:30 AM
timmy0tool's Avatar
timmy0tool
not a lot of US stateside folks that have or know about these but i would ask the 1st gen IS or even some supra folks.
Old Feb 14, 2022 | 11:45 AM
ryanboost's Avatar
ryanboost
Thank you, kindly advise
Old Feb 14, 2022 | 01:40 PM
Arsenii's Avatar
Arsenii
Hello,
Is there any particular reason you are looking for an upgrade? I wouldn't suggest to go higher than about 110-120A alternator on the stock system, they weren't designed for such loads, for a bigger amperage, you will likely need a new B+ wire and ALT fuse.
An alternator off of 3S and 5S engines look an awful lot like the ones on the 1G engine. To make sure, you can take your alternator to any car parts store and compare it with the one for some 2000 Camry, which there should be plenty of them.
P.S. I knew Altezza came with 1G engine, but I never knew there was an IS200 sold here.. I wonder how much cheaper it was compared to its JZ counterpart, since in Japan, it at least makes sense from their tax policy..
Hope this helps and best of luck!
mojito33
Nov 21, 2018 08:18 PM
Lexnek
Maintenance
Apr 20, 2017 05:41 AM
landarc
Oct 22, 2005 02:22 PM
