IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Altezza manual shifter bezel
Old Mar 30, 2021 | 10:17 AM
2hats's Avatar
2hats
Default Altezza manual shifter bezel
Hey guys! Ive finally gotten around to 5 speed swapping my 02 is300 but unfortunately my swap didn't come with the oem 5speed shifter boot/bezel, and they're as hard to find as gold online so I was thinking about using one from an altezza/is200. Does anyone know if it fits on the US is300? Thanks!
Old Apr 2, 2021 | 11:02 AM
1997Soarer's Avatar
1997Soarer
If you are referring to the Altezza shift boot with the integrated ring, yes. Auto and manual IS300s share the same plastic center console trim piece. You know where the chrome trim ring is? It surrounds the gated shifter. Well all the gated shifter parts get removed and the Altezza shift boot comes with the ring integrated. It just snaps in.
The only thing that makes US spec IS300 panels have different part numbers between autos and manuals is the shift plate that manuals come with to show you the gear layout.
EDIT: I found my IS300 boot. It has a built in plastic ring with tabs. Not chrome tho, I think you reuse that over this
58808-53010-C0 COVER SUB-ASSY
2jznosheet
Performance
Dec 4, 2018 02:41 PM
tetsussaig
12
Nov 21, 2017 10:59 PM
Midengtoy
Apr 17, 2013 01:41 PM
